whats the BEST throttle body for a Skunk2 Maniflods
I got a Skunk2 Maniflod for my B16 what and how big of a throttle should i get?
Re: (SleepnCiViC)
sorry for goin little of topic but would it be worth havin ek9 t/b and im worked on (bored etc) or leave alone and just bolt on to b16 with just basic mods ?
Re: (vti444)
The inner bore on the skunk2 manifold is 64mm. Some people bore their throttle body out to match the skunk2 bore for a smooth flow.
Modified by Echo7847 at 5:31 PM 2/26/2004
Re: (dpw41285)
there are some places that service your oem throttle body, they will bore it out for like $100. just get it matched to the skunk2 and you'll be set.
I want to be MADE into Ice-T
Re: (akumaracer)
bump i was wondering also, i got a jdm b18c with a skunk2 IM and i was wondering about the TB as well, i might look into a typr R TB not sure tho, does any one have the same setup or and info on that ? thanks
ive got ek9 ctr t/b and i/m waitin to go on my b16. once these are on its about as far as ill go engine wise apart from maybe stage 2 cams somewhere down the line. got em cos matched to work well with each other but is it worth the $ to get em worked on or will i get no more gains ?
mods are simple i/h/e, cams,decat, unichip
Re: (NA_B16a2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B16a2 »</TD></TR><TR><TD CLASS="quote">Get a Spoon TB </TD></TR></TABLE>
That's what I did. They bolted up great.
Re: (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote">
That's what I did. They bolted up great.</TD></TR></TABLE>
Yeah it's a great fit
Re: (NA_B16a2)
The Spoon TB is to BIG for the Skunk2 IM. correct me if im wrong but isnt the Spoon TB 70mm and the Skunk2 IM 62mm or 64mm i cant remember
Re: (TodaPwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaPwr »</TD></TR><TR><TD CLASS="quote">
The Spoon TB is to BIG for the Skunk2 IM. correct me if im wrong but isnt the Spoon TB 70mm and the Skunk2 IM 62mm or 64mm i cant remember</TD></TR></TABLE>
Incorrect. 70mm opening tapered to a 64mm outlet. It is just like an ITR but tapered to 70mm at the opening. It comes with new sensors too w00t w00t.
Re: (King Tut33)
Incorrect. 70mm opening tapered to a 64mm outlet. It is just like an ITR but tapered to 70mm at the opening. It comes with new sensors too w00t w00t.</TD></TR></TABLE>
Coo thanks man i think i might get one then
Moderator
Re: (NA_B16a2)
bling!!
just a b16 tbody
bling!!
just a b16 tbody
deary09
04-23-2013 11:29 AM
