5 wire to 4 wire conv
Old Feb 25, 2004 | 10:14 PM
streetstylenperformance's Avatar
Default 5 wire to 4 wire conv
Does any one have a diagram for the conversion from 5 wire (hx) to 4 wire for p28 to run off of. I don't know which of the 7 leads are to be used to connect to the four wire??????
Old Feb 25, 2004 | 10:18 PM
ARIZONA's Avatar
Default Re: 5 wire to 4 wire conv (streetstylenperformance)
you need to move the ORG/BLU wire from the 4th connector at the shock tower harness, and move it matching with the WHT wire on the 4 wire embedded engine harness.
Old Feb 25, 2004 | 10:20 PM
Default Re: 5 wire to 4 wire conv (ARIZONA)
that's it? It sounds to easy, I have the pin out but my wires are not the same colors as the pin out thus I don't know which is + and - heater or sensor
Old Feb 26, 2004 | 04:35 AM
EE_Chris's Avatar
The wideband O2 uses a different style connector than a standard 4 wire model.
How can moving only 1 pin make everything work? Don't you have to do some cutting and soldering as well?
Old Feb 26, 2004 | 03:28 PM
Del_Sol_s's Avatar
Just run the four wires directly to the ecu. Thats what i did works fine.
chrismanis
Nov 6, 2014 12:07 PM
Spicoli v 3.0
Audio / Security / Video
23
May 3, 2007 05:25 PM
D16Z6racing
Mar 21, 2007 05:56 AM
5STAR3
Jan 22, 2004 03:47 PM
