96 ITR brakes onto a 97 hatch
Okay, I've waded through the 96 ITR brake thread and could'nt find a couple of answers.
Did anybody ever find a rear disk that is usable other than a brembo blank or a redrilled rotor?
I've never done a brake swap (front or rear) so will I need a ball joint puller for the fronts (to get the hub off)? I would assume that I will.
Will the prop valve on a 96ITR (no abs) bolt right up to my stock lines without reflaring?
Aside from the master cylinder, brake booster, prop valve and of course all four corner's brakes what do I need? I know I need new fluid.
I cannot reuse my stock E-Brake cables can I? I seem to remember hearing that I could.
I hope there are enough people with this setup to help me get some feedback.
Re: 96 ITR brakes onto a 97 hatch (Ricey McRicerton)
1. rear disk i dont know, from the FAQs in this forum it says rear unknown on top of page 3
https://honda-tech.com/zero...age=3
2. swapping out the front you might need a ball joint remover but you can always pound it off with a rubber mallet. as for the rear, air tools would help but its pretty much simple bolt off with wrenches and ratchets.
here is a good tutorial to how to remove the balljoint, check out number 8
https://honda-tech.com/zerothread?id=382416
3. mine already had disk brake so i didnt need to change the prop valve so i'm not help here
4. yes you'll need fluid
5. i'm not 100% sure but you might need an E-brake cable DONT QOUTE ME
i wasnt much help but hopefully someone else that has done this will chime in.
Re: 96 ITR brakes onto a 97 hatch (Kid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">1. rear disk i dont know, from the FAQs in this forum it says rear unknown on top of page 3
https://honda-tech.com/zero...age=3 </TD></TR></TABLE>
Yeah, that's why I was asking agian. I already saw that and waded through all 5-6 pages of that thread he started about it. I got most of my questions answered, but was still a little unclear on these things. Keep the opinions coming guys!
Up one time for the daytime crew. I hope somebody can help me out with this. Where are all of my rear disk swappers??
Re: (Kid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">97 hatch dont have rear disks.
bump for some imfo</TD></TR></TABLE>
Correct. Thanks. I hope the ones I have will work, but don't know what other brake cables I could use short of some CTR ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Okay, I've waded through the 96 ITR brake thread and could'nt find a couple of answers.
Use the itr brake cable, its easier. Everything bolts right up. Joint pullier a must if you have pipe cleaner arms.
As for the rotors Endless makes for the 96itr and they have them in stock. They are little pricey but good stuff. If you have any question like Spoon caliper with Prelude IM me.
Re: 96 ITR brakes onto a 97 hatch (souk)
Thanks agian man!! I bench over 240 and I have a buddy who benches over 330, so I think between the two of us we can get by without a ball joint puller. I'll go see how much they are though. Thanks a bunch man!
EDIT: Just found out I need rear SI lines, so I'm going to post it in here so I don't forget!
Modified by Ricey McRicerton at 12:34 AM 2/28/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Thanks agian man!! I bench over 240 and I have a buddy who benches over 330, so I think between the two of us we can get by without a ball joint puller. I'll go see how much they are though. Thanks a bunch man!</TD></TR></TABLE>
"Why use your muscle when you can use your mind," that was what I said to my brother when he pounded on it for about 15 minutes. So have fun and enjoy comments like "Why don't you get some real Type-r instead of painting your HX rims."
Haha, funny ****. I roll on painted HX rims now (talk about irony). Anybody know how much a ball joint puller runs??
To run down what I have and need
What I have:
4 brake setup
MC
Brake Booster
Prop Valve
Rims
What I need:
Fluid (how many bottles? 2? )
Rear SI lines
ITR e-brake cables
What I have:
4 brake setup
MC
Brake Booster
Prop Valve
Rims
What I need:
Rear SI lines
ITR e-brake cables
2 bottles of fluid will work. I think you have everything. Yeah, just use the brake cable that it comes and maybe a six pack of your choice of beer equals a good day.
Yeah I bought spring compressors as well when I could have rented them. I just like tools..what can I say. One more question....wtf did you guys do about the hubs on the brakes being 36mm and my stock axles only being 32mm??
might as well go stainless steel lines for the 99-00 si's while you're at it. Some people say that the drum/disk prop valves for all civics are the same but i say BS. Get an si prop valve. 98-01 ITR MC/BB are pretty much bolt on for civics. I have it on my car. that's about it. Some pads and you're STRAIGHT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Yeah I bought spring compressors as well when I could have rented them. I just like tools..what can I say. One more question....wtf did you guys do about the hubs on the brakes being 36mm and my stock axles only being 32mm??</TD></TR></TABLE>
http://www.harborfreight.com/c...36861
cheap at harbor freight.
Re: 96 ITR brakes onto a 97 hatch (soundbomber)
I plan to get the stainless lines, but what do I do about the difference in hub sizing?? Anyone??
Okay guys, I have yet to find anybody who can get me the stainless lines that I need by the time I need to do the install. Now Im stuck checking junkyards and SIs are NOT easy to find here. Can I use the rear brake lines off of an Integra?
EDIT: I bought a balljoint puller today. We have a local harbor frieght that I just ofund out about and bought that exact one in the link!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Okay guys, I have yet to find anybody who can get me the stainless lines that I need by the time I need to do the install. Now Im stuck checking junkyards and SIs are NOT easy to find here. Can I use the rear brake lines off of an Integra?
EDIT: I bought a balljoint puller today. We have a local harbor frieght that I just ofund out about and bought that exact one in the link!</TD></TR></TABLE>
cool! im going to buy one from our local harbor frieght, to replace my steering rack. you like it?
good luck on your brake line hunting.
I just did the GSR rear brake swap on my 96 EX, so I hope I can help.
The way the ebrake cables mounted seemed very different on the drums vs the disks. I just used the GSR ebrake cable. it was a tight fit but it worked.
As far as the brake lines the GSR also worked just fine.
I dont know the diff between a hatch and a coupe but I hope this helps. if you have any questions PM me
Ricey McRicerton
10-15-2008 05:05 AM
weezy2525
01-21-2008 04:28 PM
Bullitt
10-21-2006 08:25 AM
