Ground Control experts...spring rate, need help???
I just bought some used ground control and I don't know which spring goes in the front and the rear...here are the numbers on the springs...
GC 180.64.44 and GC 200.64.58
Can someone tell me which one goes in the front and which goes in the back...The person I bought it from said it was from a Del Sol....
Re: Ground Control experts...spring rate, need help??? (sting94112)
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by
edit: Taken from the RR/AC forum FAQ (written by Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sting94112 »</TD></TR><TR><TD CLASS="quote">GC 200.64.58 in the front </TD></TR></TABLE>
Cool thanks, but why is the longer ones in the front...my a stupid question but I would expect it to be in the rear...
Re: Ground Control experts...spring rate, need help??? (igone916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igone916 »</TD></TR><TR><TD CLASS="quote">
Cool thanks, but why is the longer ones in the front...my a stupid question but I would expect it to be in the rear...</TD></TR></TABLE>front is heavier
Re: Ground Control experts...spring rate, need help??? (zerogravity)
not always true there is the "jdm" spring rate thing. with the heavier rates in the back and the lower rates in the front. you could run either way. but with that low of rates i would run it with the heavier rates up front
Solbros Owns Me
Re: Ground Control experts...spring rate, need help??? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">not always true there is the "jdm" spring rate thing. with the heavier rates in the back and the lower rates in the front. you could run either way. but with that low of rates i would run it with the heavier rates up front</TD></TR></TABLE>
that would be USDM.
JDM coilovers run higher front
that would be USDM.
I run 350front/ 420 rears. This allows the back end to be a little looser for going around corners in an autox event. My spring weight is pretty friendly compared to some and its totally streetable.
Check this out. http://www.norcalcrx.org/tyson/coilover.html
This came from the sticky post in the road race/ autox forum...theres alot of really good info there.
call up ground control. they will tell you in seconds.
i told him the serial number and he didnt even look it up. he knew it off the top of his head
Re: (SleepnCiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepnCiViC »</TD></TR><TR><TD CLASS="quote">200/180 ehhhhh very soft!!!!!!</TD></TR></TABLE>
that is the length. the spring rates are 330/250
Re: (sting94112)
that is the length. the spring rates are 330/250</TD></TR></TABLE>
hey where do you look for the spring rates...
Re: (igone916)
hey where do you look for the spring rates...</TD></TR></TABLE>
LOL Look 4 post above yours....
lilo_goki
16
03-10-2008 10:16 AM
Cole D
Suspension & Brakes
10
07-10-2007 07:05 AM
Tweakmeister
05-31-2003 02:33 PM
