!!HELP!! why is my car over heating
ok i have coolant/water engine is running great i have oil, when i drive the car is fine ,the engine temp is normal ,but when im stopped at a light or stopped with the car on the engine temp climbs almost all the way up , it scares me so i shut of my car everytime it starts to do it, but as soon as i start moving again right away it goes back down .please help me out
Re: (alloutmotor)
make sure you have coolant, bleed the system, and replace the thermastat. If it still does it, flush your radiator and change your waterpump/timing belt.
Re: (alloutmotor)
we had this problem with the ls\vtec we did and we found that the relay for the cooling fan was bad, you can also find out by revving it up when it starts to everheat, if it cools back down, could be a bad waterpump, or by putting the heat on and turn it all the way up. if it comes back down, another indication of waterpump. check the small stuff first, like thermostat, and radiator cap. the relay is like $65 from honda for the 94 integ. i was working on. so check to see if your fan is coming on.thats all the advise i have, hope it helps.
Re: (alloutmotor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alloutmotor »</TD></TR><TR><TD CLASS="quote">wow...could it be your water pump being bad or something..thats the only thing i can think of....</TD></TR></TABLE>
if youre at a stop and u notice the temp going up its most likely the water pump is going out
before going through all that drain it or whatever then fill up with coolent, not water. happend to me when i overheated and filled with water. temp jumps up when it's sits for too long.
Re: (Rhythm Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm Racer »</TD></TR><TR><TD CLASS="quote">thanks for the help. how much is a new water pump, is it hard to install</TD></TR></TABLE>
well a water pump install is more for the 'advanced' mechanic
youre gonna need to remove and reinstall the timing belt (might as well replace that too since its coming out) when you replace the water pump
Re: (JDMalphaSKATER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMalphaSKATER »</TD></TR><TR><TD CLASS="quote">
if youre at a stop and u notice the temp going up its most likely the water pump is going out</TD></TR></TABLE>
not always..... i just had a **** load of cooling problems and it turned out to be a bad radiator... replaced with new one and no more over heating....
all teh cases i have seen where the car is fine while moving (cool air hitting the radiator) and over heat when it stops ( no air hitting radiator) has been because the fan wasnt coming on. change th elittle stuff first like thermo stat, radiator cap check the fan as well and bleed the system really good. befiore you start tearing apart into a new water pump or head gasket..
it amazes me how many people in here immediately start thinking WATER PUMP lol.
Unceasing Measure
You people know that the water pump runs as long as your car's on, right? Idle speed isn't enough to make a water pump not cycle fluid through the system.
It's almost 100% the fan relay or something. Just go tell us if your fan ever turns on after your car is warm. If your temp needle is also freaking out and going from one extreme to normal in like ten seconds it's quite possible that your temp. sending unit is bolluxed up too. Has it actually overheated yet?
And turning your car off when the temperature is peaking isn't necessarilly a good way to stop damage from being done...in fact, continuing to drive would be best.
wouldnt your motor be DEAD if the pump died?
anyways feel the upper and lower rad hoses (after warming car up) , if one is hot and the other cold. its your thermostat.
also see if the fan even turns on after 5 -10 min. it should.
last, bleed the system of air. and make sure your coolant is 50%water and 50% coolant. you cannot run on 100% coolant or 100% water.
Re: (Turbo E 604)
ok its the fan it doesint turn on i wanna run a toggle switch into my car for the fan like one other guy on this thread said .how can i do this
Re: (Rhythm Racer)
Take a multi meter and check to see if you have 12v going to the fan.
Then check the sensor that on the thermostat housing, it might be bad.
If the fan does work......a quick fix is by taking that same sensor thats on the thermostat, and splicing both wires together. It will make the fan run at all times while the car is on, until you fix the problem. (just a temp fix) also you can put a paper clip in the plug to tie up both wires either way.
Good Luck
Good Luck
Utilitarian
09-14-2007 11:20 AM
Gabe_
12
06-13-2003 02:47 AM
