are spark PLUG WIRES interchangeable?
Old 02-27-2004, 11:15 AM
ApexiChild's Avatar
Default are spark PLUG WIRES interchangeable?
my bro needs some. I have an extra set of OEM gsr spark plugs. I think they should just work fine.....
what are the difference between them?
-lenght of the plug as it goes down to the spark plug?
Old 02-27-2004, 11:16 AM
Unceasing Measure
Archidictus's Avatar
Default Re: are spark PLUG WIRES interchangeable? (ApexiChild)
Get the right wires. The incorrect ones won't seal and may not reach.
Old 02-27-2004, 11:18 AM
JSJ EG6's Avatar
what car does he have?
i have a ls motor. i used a set of b16 and a set of sohc wires. they worked fine but dont fit right.
Old 02-27-2004, 11:39 AM
Charlie Moua's Avatar
Default Re: are spark PLUG WIRES interchangeable? (JSJ_EG_HATCH)
OT:
what do you do if your spark plug wire keeps poping out all the time?
only one of the pops out.
Old 02-27-2004, 11:55 AM
elwood's Avatar
Default Re: are spark PLUG WIRES interchangeable? (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">OT:
only one of the pops out. </TD></TR></TABLE>
make the metal clip on the inside smaller with some pliers.
Old 02-27-2004, 12:46 PM
Default Re: are spark PLUG WIRES interchangeable? (elwood)
thanks I'll try that.
why do they pop out? is it because of the pressure inside?
Old 02-27-2004, 12:48 PM
civboy115's Avatar
try making sure your plug is screwed all the way in with anti-sieze on the end. Mine kept pooping out and finally foiund out that it was totally unscrewed which caused it to pop out the top almost. Wouldnt have been good had i waited any longer....
but yeah i doubt thats your case, just somthing to llook into.
gl
Old 03-01-2004, 04:14 AM
Hey i just found out today that GSR spark plugs wires are about 1/2 (or less) longer than LS wires
JDM_SOHC
04-30-2007 02:24 PM
baboracus
08-18-2006 12:55 PM
slickrc
08-03-2005 06:39 AM
5lugSlug
07-19-2004 07:34 PM
SiR Kid
10-10-2002 07:49 AM
Quick Reply: are spark PLUG WIRES interchangeable?
