LS swap help
LS swap help
im getting an LS motor for my 1993 hatchback si....it is obd 1...correct.....what ecu should i use for best performance? what all do i need..i know the mounts,shift linkage, and what else what should i do to my stock wiring harness? let me know anything i have not listed....YES ialready searched but i could not find exact answers!
thank you for positive feedback!
Re: LS swap help (ekdreamer)
That is a great quote. My days of doing that are past me but definitely something I will teach my daughter to do to get back at a guy.
Sharing is caring.
Sharing is caring.
Re: LS swap help (diabl0451)
p75 is the correct ecu to use as far as what u need. Mounts,linkage,axles,halfshaft,engine and tranny. As far as wiring its plug and play no xtra wiring needed
Re: LS swap help (sLoWrAcEr)
You can just use your stock wiring harness if ur motor dosent come with one just unplug yours and put on the ls motor and thats it. Im in md and i can help ya do the swap if you come up here
would you all recomend the hasport mounts? what shift linkage is the best? if there is a best lol....thanx
Re: LS swap help (civichatch6989)
how muc hare we talking...i can get the motor and tranny in i might need some help on the wiring though.....could you make me a deal...hopefully
