bottom end bulid
bottom end bulid
if i get my bottom end completely done in my b16a 12:1 compression rods crank all that **** new Bering's oil pump water pump do u think ill be able to feel the difference big time or a little bit like how much more power will it give me all i have done now is i/e/h lighter flywheel any opinions.
All Motor Mentor
1 Post
Re: bottom end bulid (b16a27)
Unless you change your cams or do some headwork, that bump in compression will only yeild about an 8% gain in power (4% for every 1 full point gain in comp) or 10-12 hp. Unless you're doing a stroker kit I see no reason for changing the crank or rods. Simply using CTR pistons and a thin headgasket could get you to that 12:1 comp ratio in a B16a.
GreddySi99
09-27-2003 06:44 AM
