Greddy turbo kit is it worth it???
Used Greddy 15g turbo kit, Greddy Type 31 Intercooler kit and HKS SSQ BOV with the flange already welded on pipe.
$1100
also what are the numbers i can expect from putting this kit on? what are the gains it should provide..
$1100
Re: Greddy turbo kit is it worth it??? (litterbox)
id assume a d series b/c of the turbo size
the numbers all depend on how much boost you are pushing and your fuel setup (and obviously any engine work)
he bought an s2000 so i think hes parting out his civic. Thats not a good reason to buy a turbo kit..(if seller needs money) but is the price hes asking a good deal?
Re: Greddy turbo kit is it worth it??? (jdmvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvic »</TD></TR><TR><TD CLASS="quote">Used Greddy 15g turbo kit, Greddy Type 31 Intercooler kit and HKS SSQ BOV with the flange already welded on pipe.
$1100
also what are the numbers i can expect from putting this kit on? what are the gains it should provide..</TD></TR></TABLE>
$1100 is slightly high. Around $900-1000 would be a little more reasonable, although I did get around $1200 when I sold my kit. As for gains? Well, figure 5psi will net you around 170hp approximately. I ran the Z6 kit on my Y8 with the hack setup and was dyno tuned at 7psi. However, the HKS MBC I was using was ******* leaking and sticking, so I was only able to put down 179 flywheel hp and 175 lb-ft of torque. Not horrible, but the damn boost controller was broken to hell. HKS said it was perfectly fine, though, when my shop sent it to them for inspection.
$1100
Re: Greddy turbo kit is it worth it??? (Daniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel »</TD></TR><TR><TD CLASS="quote">
$1100 is slightly high. Around $900-1000 would be a little more reasonable, although I did get around $1200 when I sold my kit. As for gains? Well, figure 5psi will net you around 170hp approximately. I ran the Z6 kit on my Y8 with the hack setup and was dyno tuned at 7psi. However, the HKS MBC I was using was ******* leaking and sticking, so I was only able to put down 179 flywheel hp and 175 lb-ft of torque. Not horrible, but the damn boost controller was broken to hell. HKS said it was perfectly fine, though, when my shop sent it to them for inspection. </TD></TR></TABLE>
You put down 179 FLYWHEEL horsepower? If so, that sucks.
Re: Greddy turbo kit is it worth it??? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
You put down 179 FLYWHEEL horsepower? If so, that sucks.</TD></TR></TABLE>
Yeah, the boost controller was acting up pretty badly. The day I was dynoed, I made a thread in the FI forum to complain about my numbers.
ghostrider dc2
02-19-2005 08:52 AM
