Help with a jdm b16a swap
My idle is all messed up. It goes up and down between 1500 to 2500. I switched my idle control valve and it didn't do a damn thing. What else could it be?
Re: Help with a jdm b16a swap (b16a4dr)
Is your check engine light on? If so, put a paper clip in the small two wire connector down by the ecu. And then, count the number of times it blinks.
Long blink = 10
Short blinks = 1
Then look up the code at the top of the forum. If you are throwing multiple codes, there will be a brief pause in between flashes.
Long blink = 10
Short blinks = 1
Sounds like you have a vacuum leak, so check all your vacuum lines and if they are fine then it could be the Fast Idle Thermo Valve (FITV). Its around the t/b and its notroious for vacuum leaks. There is a write up somewhere on HT on how to try an fix the FITV before resulting to buying a new/used one. Try searching for FITV fix.
Re: Help with a jdm b16a swap (97mini-me)
I checked my engine codes and it is throwing a idle air control valve number so the only thing that I can come up with is that the one Car Quest sold me was bad. It was also throwing a MAP sensor code, if that means anything.
Re: Help with a jdm b16a swap (DelSolDon)
the FITV was the prob....we took it off tonight and screwed it all the way down and it was fixed!!!
thanks guys
thanks guys
Bashy Vtec
10-08-2017 11:44 AM
Kooner450r
12-27-2004 09:33 AM
