overheating question
Ok so the other day my car overheats, no hot air from heater, bottom radiator hose cool, top hot and hard. Thermostat right? Well I changed it with a failsafe one that locks open if it goes bad. Put it in started car, topped everything off. was still blowing cool for a few. turned it off, let it cool, topped it off again. next day I was driving around all day with heat at normal temp. Then all of a sudden the temp goes way up, not to the red but pretty damn high(fan is on). Heat is still working so I know its not the Tstat. after a few it drops to normal. runs normal for a few then jumps back up till I got home. what could be wrong? please help me out.....
Re: (decible01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decible01 »</TD></TR><TR><TD CLASS="quote">yeah, I bled it, and now its doing the same thing. no heat, hoses are hard, and overheating.</TD></TR></TABLE>
No heat from the heater = air in the core. You need to make sure the heater is set to "hot" when you are filling and bleeding the system, otherwise you are going to have this issue. Trust me, there is still air in that system.
Re: (Hybrid93Eg)
you could have a blockage in your heater core. easiest way to clear is to flush your system with a cooling system flush product. read directions on bottle and flush, flush, flush.
Re: (decible01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by decible01 »</TD></TR><TR><TD CLASS="quote">yeah, I bled it, and now its doing the same thing. no heat, hoses are hard, and overheating.</TD></TR></TABLE> Next time after you drive your car, park it on a dry spot. Then come out after some time/in the morning, and check if there is coolant under the car. It could be leaking somewhere. Also check if you have coolant on your carpet, it might be your heater core.
Modified by RedHB..D15B at 9:54 PM 3/3/2005
Re: overheating question (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">when you topped off the fliud, did you run the car for a little bit with the cap off to let the air out ?</TD></TR></TABLE>
also, did you have the heater on the hottest blowing the hardest ? it has to flow thorugh the heater core also.
93CamaroLT1
01-11-2010 02:59 PM
