need help with my hasports :(
this is where my motor is sitting with the 2 side mounts in.
this is how the rear lines up. its the egrr mount.
arrrrrrrrrrrrg wtf.
Modified by jbell at 1:27 AM 8/24/2005
arrrrrrrrrrrrg wtf.
Re: need help with my hasports :( (antivic)
i got the bracket from the same guys i got the mounts... i explained what i wanted them for so i assumed its all correct...
Re: need help with my hasports :( (jbell)
Put the rear mount in first. I had a problem with mine sitting funny too, and when we started with the rear, it went in a lot easier...Still a pain in the ***, but easier
Location: With my POS D15B2, Whereever whenever, United States
Re: need help with my hasports :( (92HatchB16)
the b16 t mount and the d16 t mount are different
I assume if it is that off, you have a d series t mount
Re: need help with my hasports :( (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda »</TD></TR><TR><TD CLASS="quote">the b16 t mount and the d16 t mount are different
I assume if it is that off, you have a d series t mount</TD></TR></TABLE>
t mount?
the rear bracket?
t mount?
the rear bracket?
Put the rear mount in first. All you need to do is take the other two mounts off, and start with the rear mount. I spent hours trying to get the rear to line up, and it didn't work until we took the other mounts off and started with the rear. Try it...
I am a (Trial User) Army
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HatchB16 »</TD></TR><TR><TD CLASS="quote">Put the rear mount in first. All you need to do is take the other two mounts off, and start with the rear mount. I spent hours trying to get the rear to line up, and it didn't work until we took the other mounts off and started with the rear. Try it... </TD></TR></TABLE>
Listen to her!!
Rear mount first, put bolts in but keep them loose. Then mess with the sides.
Listen to her!!
looks like you may be in need of a mount. if you got the first 2 in, the 3rd should not be that off. it looks straight too...
the brackets are the same... it's the rear mount that is different between the d and b in your eg sir.
Re: need help with my hasports :( (idriveadelsol7)
i always put the rear mount in first - the side mounts you can have in but most time cause complications - remember when removing the rear is gen the last mount out- which means its the first one it - do every thing in reverse
Re: need help with my hasports :( (b204dr)
i cant put the rear mount in first or the sides wont even be close.
is there a hasport model number for b16 into a del sol?
i have egrr egrh and eglh.
any b series mount should line up - the engine bay of a sol is near the exact same thing as an eg except the front rad. support
Yea, the B-series mounts are all the same. Call up Hasport and they should be able to help you out with it. They are very helpful if there is a problem fitting the mounts.
i know that. i just cant fathom whats going on here. its should be a traight swap. according to the hasport site, these are the right mounts.
Re: (jbell)
That is really wierd...I had the same problem and we fought and fought with it and then did the rear first and it was fine. Does the motor look like it is sitting too high or too low, or facing off to the side at all??
Re: (jbell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbell »</TD></TR><TR><TD CLASS="quote">no, i think i got the wrong rear bracket. </TD></TR></TABLE>
so take it out call up hasport - tell them you think you have the wrong bracket and they will work with you.
Re: (b204dr)
well, they told me i need egrb, on the site, it looks just like this one... but according to a few other places, i need a 94-01 Integra rear transmission Bracket for b16 swap into an eg. its longer in the pics, and looks like it would work.
