clutch problem... HELP
just installed a jdm d15b in my automatic del sol s (d15b7).
i'm getting this weird noise comming from my engine. sort of like a sliding your hand across a piece of paper slightly when i release the clutch (happens in neutral and in all gears). when i step on the clutch, the sound stops. it only makes that noise when the clutch is engaged (not stepped on)
Re: clutch problem... HELP (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Input shaft bearing is going. Mine dose the same thing.</TD></TR></TABLE>
you mean that bearing the fork connects to? it's new... i just got a new clutch and flywheel... we kind of beat the **** out of it to put in in though...maybe that's y
Re: clutch problem... HELP (idriveadelsol7)
Did you re-surface the flywheel? If it is warped I believe it would cause the same kind of noise you're experiencing.
check your throwout bearing... i know its new but it can still be bad... mine made a loud noise when i let the pedal out.. expecially when taking off.. kinda like the sound of sandpaper against metal
i know it's not the flywheel or the clutch... when i engage it (my foot is taken off the pedal) than it makes that scruffing, sand paper noise.
1 Post
Re: (Cypher0117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cypher0117 »</TD></TR><TR><TD CLASS="quote">i thought for the input shaft bearing to be bad, the noise would occure all the time. please correct me if im wrong</TD></TR></TABLE>
It would. But if it was a throwout bearing it would growl, mostly when the clutch is all the way out.
Re: (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
It would. But if it was a throwout bearing it would growl, mostly when the clutch is all the way out.</TD></TR></TABLE>
i don't get a growl...i get a scruffing like sand paper.
idriveadelsol7
08-26-2005 04:35 AM
JRciv
04-13-2005 09:29 PM
