will d16y8 spark plugs fit into b18c1?
Mr. Badwrench
Re: will d16y8 spark plugs fit into b18c1? (carjacker006)
these are the specs in the y8 plugs:
14mm thread, 19mm(3/4") reach,16mm( 5/8") hex, extra projected, resistor, double platinum, .044"gap
these are the specs on the gsr plugs:
14mm thread, 3/4" reach, 5/8" hex, gasket seat, ISO length, resistor, projected tip, fine wire (0.6mm) iridium center electrode, tapered cut ground electrode, .044" gap
so the installed height and stuff is the same BUT:
looking at the double platinum plugs on sparkplugs.com,
the stock numbers are different. possible heat ranges are different. they will fit in and may work, but dont hold me to it.
Jimi Hondrix
07-19-2015 05:22 PM
