How can you tell the difference, in appearance, on a motor with....
Auto and Manual? I know this is a pretty noob question, but I would like to know.
If you looking at the motor, how would you know that, then, and there, if it was a manual or auto, here is an example:
This is a Manual cause someone took out the Tranny right?
Re: How can you tell the difference, in appearance, on a motor with.... (RockLee`)
the motor is a motor, the tranny decides if its manual or auto... you can bolt a manual tranny to a motor that came auto from the factory and vice-versa
Re: How can you tell the difference, in appearance, on a motor with.... (Sleepy_Red_hatch)
good info, here's a question.
So my car is a manual... and let's just say i bought a auto motor. Switching out the tranny would ..... make it work?
Former Moderator
Look on the side of the engine where the transmission bolts up - do you see a solid cast iron flywheel, or a steel plate with a bunch of holes? If it has a thin steel plate the the engine was originally bolted to an automatic transmission.
If there's neither then it will be nearly impossible to tell, and honestly it doesn't make a difference anyways.
The engines are interchangable regardless of what type of trans was originally bolted to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` »</TD></TR><TR><TD CLASS="quote">good info, here's a question.
So my car is a manual... and let's just say i bought a auto motor. Switching out the tranny would ..... make it work?</TD></TR></TABLE>
there is no such thing as an auto motor. if your car is a manual, then you already have the hydraulic lines for the clutch, so all you need is a manual tranny (with shift linkage) and a manual ecu.
1 Post
There will either be a flex plate , automatic, or a flywheel , manual.
To fit a manual transmission on an automatic motor or visa versa all that needs to be done is swap these parts.
even if it was connected to an auto tranny and had a tq converter and plate on it, you just need to remove them and put on the flywheel.
My b18 engine was from an auto
Re: (pdiggitydogg)
from the last picture you show it looks like you have a flexplate on there, so you will need a flywheel and new flywheel bolts and a manuel tranny
Re: (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 »</TD></TR><TR><TD CLASS="quote">from the last picture you show it looks like you have a flexplate on there, so you will need a flywheel and new flywheel bolts and a manuel tranny</TD></TR></TABLE>
huh? where do you see that
i see nothing connected to the tail of the crankshaft.
1 Post
Re: (krispincreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krispincreme »</TD></TR><TR><TD CLASS="quote">Could u then hook up a 6 spd somehow? Aren't there conversions for 6 spds?
Hahah....Thud.
Hahah....Thud.
Former Moderator
Re: (krispincreme)
Yes it's called buy a K20A swap from an Acura RSX Type S and do the full swap and spend over $7,000.00 at he very least.
...but a 6-speed on a B18B engine? Not unless you get some custom $10,000.00 Quiafe if they even make one, which I don't think they do.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
...but a 6-speed on a B18B engine? Not unless you get some custom $10,000.00 Quiafe if they even make one, which I don't think they do.</TD></TR></TABLE>LMFAO, yeah and $10,000 is somewhat of a conservative number on a custom 6spd for a B-series, I did some research a while back, can't remember the company, but it was closer to the $12,000 mark, ouch.
on the new engine its and auto the only diffrence, throttle boddy hasa kick down cablefortheauto tranny, andi am pretty sure the cams are slightly diffrent then 5 speed cams. atlease the d16z6 auto-5speed and b16 auto-5 speed cams differ....might wanta search it thou. other than that get a flywheel and clutch, the fidanza lighten flywheels are nice, they free up some engine power....hope this helps u
* B A N N E D *
1 Post
Re: (punkracer)
this guy made a custom 6 speed tranny for an old Corvette and on the highway he did somethin like 80mph at 1200rpm. The topspeed was nuts, but cost effectivly, it was unpractical.
Anyway, See that number on the motor? Take that to honda, maybe you can find out what car it came from, and see what that car was OEM. With a B18, the difference in wear on a auto over a manual is almost negligable anyways.
You can do a lot of homework, and check all the sensors on your harness, im sure there is a sensor for auto cars thats not plugged the same way on a manual car. Ya can check the ECU if it came with the motor.
Joshyboy2929
05-20-2018 06:17 PM
