??? [B]SS fuel line[/B] question ???
??? SS fuel line question ???
I am in the process of upgrading to SS fuel lines and have a question for people that have done this.
Heres the plan... -8an line from the stock fuel filter to STR fuel rail. from STR rail I will use -6an line to connect to SARD fuel pressure regulator. from regulator to return -6an.
Heres the question... what is the oulet size of the <U>OEM fuel filter</U>?
Re: ??? SS fuel line question ??? (JICEK9)
Ditch that FMU you got and get a EMS,DSM 450cc injectors(always dirt cheap $50.00-$70.00),10watt 10ohm resistors or obd0 resistor box + get it tuned by Shane @ Elite and your superchargered sohc vtec will be running at its best....
Re: ??? SS fuel line question ??? (H-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T »</TD></TR><TR><TD CLASS="quote">Ditch that FMU you got and get a EMS,DSM 450cc injectors(always dirt cheap $50.00-$70.00),10watt 10ohm resistors or obd0 resistor box + get it tuned by Shane @ Elite and your superchargered sohc vtec will be running at its best.... </TD></TR></TABLE>
has NOTHING to do with my question
Re: ??? SS fuel line question ??? (litterbox)
the CORRECT answer is here on this link
https://honda-tech.com/zerothread?id=1349700
thanks for everybody that tried tho
you could just cut off the compression fitting and take it to where your going to buy the fitting from and match it up. i think also you will have to use a special fitting, i'm not sure tho'. you need a AN flare male in stead of the usual compression style.
I am a (Trial User) Army
Re: ??? SS fuel line question ??? (baseballinmyass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">the CORRECT answer is here on this link </TD></TR></TABLE>What's the correct answer? I didn't see it in the therad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">What's the correct answer? I didn't see it in the therad?</TD></TR></TABLE>
the seconed post. answers the question. infact, he allready sent me the part.
OMG THE GOGGLES
06-27-2011 07:05 PM
