Manual transmission coming out of gear?
Old 06-08-2014, 03:37 PM
candm2000's Avatar
Default Manual transmission coming out of gear?
Hey guys, I have a 2000 civic d16y8 and it's coming out of 2ed gear when slowing down, I just bought the car, the axles are bent, who knows how that happened but it's a good quarter inch movement, and by that I mean its very out of round. Could this cause the car to come out of gear? I just replaced the transmission mount and also the bottom right mount. When you give it gas and left off fast the shifter moves a lot. Any ideas? Could this mean it has a bad transmission? Thanks in advance.
Old 06-08-2014, 04:36 PM
Former User's Avatar
Default Re: Manual transmission coming out of gear?
Yes
Old 06-08-2014, 04:57 PM
candm2000's Avatar
Is there anything else could cause this? I herd motor mounts could cause this also, what are your thoughts on that?
Old 06-08-2014, 05:00 PM
Replace the bad axles and carefully inspect the rear and left engine mounts, as well as the two front torque mounts. Replace any bad mounts. Then go from there.
Old 06-08-2014, 07:30 PM
Koko4's Avatar
Also don't overlook the bolts that hold the transmission to the engine. I had a bad vibration for over a year, replaced a TON of stuff trying to chase the problem, and it turned out to just have two bolts that were out about 1/16". Once they were tightened down..the problems went away! Start simple!
Old 06-09-2014, 03:48 AM
candm2000's Avatar
Awesome, thanks for the feedback guys, I'll get those done like you said and go from there. They would have to be done along with the hubs regardless. I'll also check those bolts, I did notice that someone had the blots loose already at one point, you can see the wear from a wrench being on it. I also did check the fluid for the transmission, there was fluid right to the top of the bolt hole.
toicy4ya
11-15-2012 10:23 AM
karrar55
02-13-2011 09:22 PM
car5car
02-28-2009 08:07 PM
jerBEAR
09-27-2006 05:14 AM
Azn Kenny
11-19-2005 05:42 PM
Quick Reply: Manual transmission coming out of gear?
