d16z6 smoking after rebuild
I have a 93 civic ex with a d16z6 I just rebuilt everything is new I got a new head about a month before I rebuilt the bottom. I just started it for the first time and let it run for a while hoping the smoking would stop after the rings set in but it didn't I got it bored .50 I'm lost any suggestions on what I should check?
Re: d16z6 smoking after rebuild
this isn't how you break in piston rings
follow the oil change schedule for break in like its your job.
-chris
of course not. im sure the procedure for break in calls for a couple passes up the street. get her up to second gear and accelerate "quickly" to about 5k rpm a couple of times. this will seat the rings.
-chris
-chris
Yes. As in ".5mm" which is the first acceptable boring limit on stock d-series block, making it 75.5mm. Otherwise known as .020" over.
Oil change schedule. Every 3 months or 3k miles. Standard practice.
Now on to the point. Dumb question: did you purchase new pistons and rings with the proper bore? 75mm pistons and rings will not work in a 75.5mm block, in case that wasn't obvious.
Now we need to talk about what kind of smoke you're having. If you're burning oil (bluish smoke) then you probably have a hemorrhaging failure somewhere. Improper ring installation, bad valve seal, etc. If it's white smoke then you could be burning coolant and that is from coolant getting into the combustion chamber from an improperly installed head gasket. We need more information on what you've done and what exactly is happening. Pics and videos will be your witness.
FWIW, all the procedures I have read on seating new rings and such always say to take the car out at low speed and take up to a reasonable rpm and then let the engine decelerate on its own to allow downward drag to force the ring up and mate with the cylinder wall as the pistons go down, while engine speed slowly drops (engine braking). More knowledgeable people might have otherwise to say.
I never narc'd on nobody!
Holy ****, no, you don't change oil after 3000 miles on a fresh rebuild. Your engine is smoking because you didn't hone it. You don't have to bore it, but you absolutely MUST hone the block, or the rings will never seat. You need to pull it apart, replace the rings again, and hone it.
For initial oil, you should also use special break-in oil, not just normal off-the-shelf oil. Fill with break-in oil. Start the car, let it warm up. Change the oil, filling again with fresh break-in oil. Dog the **** out of the car for 50 miles. I'm talking WOT pulls and engine braking at all times. Best done on a dyno or track. Change the oil again, filling again with fresh break-in oil. Drive the car normally for another 500 miles. Change the oil one last time, filling with whatever oil you like, and only after that do you switch to changing oil every 3000 or 5000 miles.
Gnarly I'm pretty sure most machine shops should know to smooth the cylinder walls when they bore an engine. Then again some machine shops suck.
I think it's that OP cant even tell the difference between oil smoke and coolant steam, and also that it doesn't seem like he broke in the engine properly
That's the standard service interval. It has absolutely nothing to do with a freshly built engine. If you follow standard service interval, your rings will NOT seal correctly, you WILL burn oil, and you WILL lose power.
A fresh cross-hatch is always best and should be performed anytime a machine shop does aaaaaanything to a block.
Unbelievable what some of these mech-savy auto enthusiasts will spout...
I figured thats what it meant, I'm not a machinist I dont know these things. So I guess a hone means make the walls rough, learn somethin new erryday
You can buy your own honing tool from an auto parts store and it can be done at home. They can be attached to a drill and use spring-loaded stones and a specific type of oil or what they call the "dingleberry" hone tool which looks like well... a bunch of dingleberries (think "sheep **** pellets embedded in wool") on tensely twisted steel.
