Help with Engine Codes
Old May 27, 2014 | 01:05 PM
kaivorth's Avatar
Default Help with Engine Codes
I have a 2001 Civic EX Coupe Manual with 150k miles.
About a year ago, my car would stop accelerating randomly, and I'd have to pull over, and turn off the car, turn it on, and I'd be set to go. Eventually the car wouldn't start (timing). Turned out to be a crankshaft sensor, found the code for it.
Year later (today) same issue. I'm pulling up the following codes:
Code 1: P0133 O2 Sensor Circuit Response Bank 1 Sensor 1
Code 2: P0420
Code 3: P0420(PD)
It possible that Code 1 is triggering the other 2? I had the P0420 for the last year, maybe its's been caused by Code 1, and code 1 is just now popping up? What O2 sensor should I be looking at?
I know they're other threads similar, but I'm not sure if last years issue has anything to do with these new ones. Thanks all!
Old May 27, 2014 | 01:36 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Help with Engine Codes
Wrong generation Civic. You're in the wrong forum.
Old May 27, 2014 | 02:15 PM
kaivorth's Avatar
Thats embarassing, lock this.
kaivorth
Honda Civic (2001 - 2005)
May 28, 2014 03:26 AM
ftrms
Jun 4, 2009 08:46 PM
~sp33~
13
Jan 14, 2009 12:30 AM
bosco500
Feb 3, 2006 01:23 PM
rasta420
43
Feb 16, 2004 12:39 AM
