Strange bogging/hesitation issue- 95 Civic
Old 06-11-2014, 06:02 PM
Stancetard Hate Monger
eghatch9295's Avatar
Default Strange bogging/hesitation issue- 95 Civic
Hi all, have a problem I am stumped with at the moment. Car is a 95 Civic EX, AT. Motor is a d16y7, all z6 accessory parts, b7 distributor, p06 ecu. Have done this swap before with no issues, and this one was running great until yesterday. It will idle all day just fine, and drive for a short while before any problems emerge. The hesitation/bogging seems to appear when the speedometer cuts out. I replaced the VSS with a spare, same issue. If I pop it in neutral, it will rev fine, and if I downshift like a manual trans, it picks back up, but it struggles to accelerate in drive. No cel's, new plugs, new wires, and swapped distributors with a spare for fun. I think the problem is somehow tied into the VSS issue. Any ideas?
Old 06-11-2014, 06:07 PM
Former User's Avatar
Default Re: Strange bogging/hesitation issue- 95 Civic
Any additional gauge problems or just the speedometer?
Old 06-11-2014, 06:11 PM
Tang87's Avatar
AT Control module? Check wiring? maybe a bad ground?
Old 06-11-2014, 08:20 PM
shotoutacc0rd's Avatar
Does the trans slip? Wouldn't be surprised being its a Honda autotragic
Old 06-11-2014, 08:37 PM
speedometer problem only. all other gauges function fine. bogging clears up after appx. 3k rpms
Old 06-11-2014, 08:53 PM
The VSS gets voltage from 15A dash fuse 24, which also supplies voltage to the main relay and fuel pump. You may want to voltage test both sides of fuse 24. Are voltages similar or different on each side?
Old 06-11-2014, 09:39 PM
i will test it first thing. if not tonight, lol
Old 06-12-2014, 01:30 PM
voltages were both 13 and change.
Old 06-12-2014, 10:17 PM
so with those results, what would the next step be?
Old 06-13-2014, 04:54 AM
The alternator is also on the same circuit. You may want to test it when the problem occurs.
Old 06-13-2014, 10:55 AM
in addition to checking on it, i am going to swap in a known good ecu. will post results.
Old 06-15-2014, 01:30 AM
Tang87's Avatar
Keep us posted. Kind of interested to see what the solution is.
Old 06-15-2014, 01:47 AM
swapped in known good ecu. speedo cut out once, hesitation was still present with speedo operating.
Old 06-18-2014, 03:21 PM
delsolintegra's Avatar
Try spray cleaning the MAP sensor electrical connector with PB Blaster. It fixed the bogging issues with my 93 del sol si auto. When you reconnect the connector use some force. Also replace the vacuum hose line from this sensor to the vacuum canister. It's about a foot long and 1/4 inch. Got it at Ace Hardware.
Old 06-18-2014, 03:59 PM
i actually saw your post searching the forum for similar issues. i did the pb thing to quite a few connectors, seems to still be hesitating a bit. im going to get in this thing with a dmm.
Old 06-18-2014, 05:44 PM
GDD Member
slomofo's Avatar
Do you have a good working MAP sensor laying around by chance?
civic4dr337
04-16-2022 05:59 PM
Chilloutdamn
03-09-2013 11:50 AM
Buddy10297
09-29-2005 07:38 PM
Buddy10297
09-08-2005 06:28 AM
Quick Reply: Strange bogging/hesitation issue- 95 Civic
