Which Size Thread Should I Use?
I'm restoring the thread of the motor mount bolt and motor mount thread in the chassis of 95 civic.
Which exact size should I use to restore? The bolt from Honda is M12 x 115 i believe...
M12 x 7.5
M12 x 1.5 or M12 x 1.25????
M12 x 7.5
Cool Cool Island Breezes. BOY-EE
Re: Which Size Thread Should I Use?
The honda bolt is M12X1.25
So....use a M12x1.25 tap to clean it up.
12mm bolt. 1.25mm between thread points. That's what it means.
I stripped that one on my teg, simple fix cut it off I used a plasma cutter due to limited apace the welded on a m12x1.25 nut. I'd just use a new nut idk where you'd find bolts THAT big/long as the OEM one not to mention the same grade.
cticknor666
03-25-2013 11:43 AM
