98 Civic - Fuse 56 blowing
I know, I know. Read the threads. Use search. I have gentleman. My situation is similar in 'Fuse 56 blowing.' Up until today I thought it was the compressor (Have gone some time without AC).
Anyway, here's the deal. I saw that the condenser fan and ground wire on the compressor weren't attached. I purchased a #8/32 Machine Screw & installed it. Fuse still pops. I swapped out the 20 amp fuse for a 30 amp and my ac has been blowing cold all day.
Any insight? Is it okay to leave the 30amp? The fact that it draws 20 amps or more makes me think there is some resistance in the fan. However prior to the fuse blowing (5-10 seconds after each start up like clock work) the fan would spin. Then stop (Fuse blew).
Any help would be greatly appreciated.
Re: Fuse 56
Blah, I thought I did. The car is listed as 1998 Civic DX, however I was told it's actually a 1999 and was made in Canada...
I was hoping you'd reply Ron. From what I've read you seem the have the most knowledge in this regard.
Re: 98 Civic - Fuse 56 blowing
It's unsafe to use a higher rated fuse than the one intended.
Re-install the 20A fuse.
If you unplug the condenser fan does the fuse still blow?
If you unplug the compressor clutch does the fuse still blow?
Unplug the connector to the fan itself.
Unplug the red wire at the compressor.
Risk of burning up your wires and car in a fire.
how unsafe is it?
If I unscrew the red wire and black ground at the compressor the fuse does not blow. This means I need a new compressor doesn't it? I was quite happy the 30 amp has been working and blowing AC all day**. Meh.
I'll have to wait till tomorrow afternoon or Saturday to do that. Things are quite busy here at the office. Do you think it would be safe to leave the 30 amp in until then?
Also, thank you for posting that diagram & for your help. I greatly, greatly appreciate it sir. I'm not exactly a mechanic. I did used to be a DIY when I had my S4. Had a stage 3 S4 and a Stage 3 Viggen pushing 26 PSI.
EDIT: I will post my results once I complete the coil resistance test.
Not very long. Maybe two 30 minute sessions.
As for the coil, are there any good reman places for these compressors? I used one before for a throttle body and had great results at a great price.
I've already mentioned the risks for using the 30A fuse. It's your choice.
The field coil itself can be replaced without replacing the entire compressor.
Well, the AC stopped working with the fuse in the very next day. Just stopped blowing cold. All fans still spin and the higher rated fuse isn't blown. Was caught up in a few things this weekend so I wasn't able to do the resistance test. Few more days of 90+ won't kill me I guess.
