93 eg dx civic mini me swap problems need some help
I have a 93 eg civic it has a d16a block with a d16z6 head and the valves are knocking really bad and misfire in cylinders 3 & 4 and I can't figure out what the problem is it has a wire tuck also but I don't think that's the problem I need some help bad
Re: 93 eg dx civic mini me swap problems need some help
P28 ECU?
CEL codes?
Cyls 3 and 4 have spark and fuel?
Have you compression tested the cylinders?
CEL codes?
Post the compression numbers, and also click the Codes link in my signature.
What color is spark at 3 and 4, and how do you know the cylinders have fuel?
The compressions at around 150 and what link and I'm not around the car to see the color of the spark and I'm pretty sure its getting fuel cuz I smelt fuel in the exhaust
If that's all the detail you have, then you'll need to put in more effort to receive help.
If you are mobile, you may not see my signature links. Check using a PC.
it says codes in his signature
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
GarageNut
07-01-2012 10:16 AM
mycvc8u2
10-17-2003 08:09 AM
