95 Civic/turbocharged D16z6 - no start after replacing the distributor
okay guys, time to put your thinking cap on!
Here is the info: 95 d16z6 turbocharged swapped into 97 ek hatch running obd1.
Car was up and running for months till the other day, just stalled and wouldnt start up.
threw code for camshaft sensor, replaced distributor, rotor and cap, code gone but still no start, did the checks according to manuals, everything points to a bad ecu, so ordered a ecu for it, still nothing...
heres the part that i dont get, i used a 95 accord ecu and the car starts right up! ive also tested my two chipped ecus in a different car and both work, just wont work in my civic.
ive checked compression, spark, fuel, air, its got it all... timing is dead on too!
at this point im stumped! the accord ecu will start my car everytime, but the two chipped ecu will not start my car, it tries to but dies seconds after it fires
anyone have any ideas id love to hear it! thanks.
Re: D16z6 no start help!
Sorry, the chipped ecu is a p28 dyno tuned on chrome, the other chipped ecu is a p06 same map on chrome, the accord ecu is stock. The p28 was the original one that was in the car. I forget the code number but after the dizzy swap the code is gone.
The Grumpiest
Re: 95 Civic/turbocharged D16z6 - no start after replacing the distributor
Getting spark? What color? Getting fuel? What's the pressure? OEM distributor?
There is a link in the FAQ on how to diagnose a no-start condition.
Yes getting spark, white, its getting fuel 40-45 psi, dizzy is reman, tried two brand new ones, thing is why can i start the car everytime with the oem accord ecu, but cant run my chipped ecu? But ive tested both ecus in a different car and they both work!
The old dizzy was a reman one that was returned as a core. Ive also returned the new core and gottend a new reman dizzy, same results each time, accord ecu will start the car up with no hicups, while the two chipped ecu for the motor will not fire.
when you put the new ecu in did you pull the chip from the old ecu and put it in the new ecu? wouldn't be the first time a chrome .bin deleted or corrupted itself.
if that was what you did try to Raeburn the .bin and see if that helps.
you said timing is dead on. did you recheck or assuming since it was good, check that it didn't jump timing. .
check all the grounds....especially the thermostat ground.
check fuses both under dash and under hood
check main relay
check main relay
check main relay
check main relay
Its a 95 accord ex oem ecu, it will start the car fine, but i cant figure out why my two chipped ecu thats been tested good in other car wont start my car which was the original chip for the motor. I have checked everything and it just dont make sense to me.
The Grumpiest
I also have diagrams for each and you never said what ECU this thing came off of. This is information you might wanna mention up front. So a virgin OBD1 Accord ECU can start it but your "chipped" ECUs cannot. Good luck to you.
Yup im sol lol, i didnt have a extra ecu at the time, just the accord ecu, thats why i tried it and it starts it! Weird weird weird.
You need to pinpoint the problem associated with ECUs that will actually be used for the car.
The more No-Start Diagnosis 101 information that you're willing to post, the faster you're likely to pinpoint the problem.
dloc82295
11-27-2012 09:14 AM
authentic plusONErandy
25
03-20-2007 09:27 PM
Jet Black
05-13-2004 08:17 AM
