92 Hatch Clutch Problems
Old 03-02-2015, 07:28 PM
cstone94's Avatar
Default 92 Hatch Clutch Problems
Short story, drove the car home one night, got in it the next morning, clutch in/engine on, wouldn't go in gear. Checked fluid, all good. Jacked the car up (thought the clutch may be stuck to the flywheel due to wet roads. Dumped the clutch in 2nd and re bled the clutch. All was good, but not for long. Started to slowly get worse when shifting, and then back to being locked out.
Sounds to me like the master cylinder is bad, bought one and will install in the morning. Also ordered a clutch just in case that doesn't fix it. Just want a second opinion. Boot on the master cylinder is slightly damp, but nothing major.
Will report back after master cylinder install.
Old 03-02-2015, 07:35 PM
Former User's Avatar
Default Re: 92 Hatch Clutch Problems
Could also be the slave cylinder. No leaks? Pedal spongy or drops to floor?
Fluid at top of clutch pedal?
Old 03-02-2015, 07:37 PM
cstone94's Avatar
Originally Posted by RonJ@HT
Could also be the slave cylinder. No leaks? Pedal spongy?
Brand new slave cylinder. Master cylinder boot is slightly damp. Pedal is decent. With the pedal down, in 1st gear, starting the car moves the car. As if the clutch is not being disengaged when the pedal is depressed.
Old 03-02-2015, 07:38 PM
What boot is wet?
cstone94's Avatar
What boot is wet?
Edited my post for clarification, master cylinder.
Old 03-02-2015, 07:40 PM
Inside cabin at top of clutch pedal?
cstone94's Avatar
Correct
Old 03-02-2015, 07:42 PM
Yeah, replacing the MC should do the trick, after a thorough bleed.
Old 03-02-2015, 07:43 PM
cstone94's Avatar
I hope so, not in the mood for a clutch replacement! I just put the motor back in it! Is bench bleeding required or can I slip by without dealing with that?
Old 03-02-2015, 07:48 PM
I know my brake MC needed to be bench bled. Not sure about the clutch MC. If needed, it should be mentioned in the instructions that come with.
Old 03-02-2015, 07:52 PM
cstone94's Avatar
Really appreciate the help man! I will post up tomorrow the results!
Old 03-02-2015, 08:00 PM
Old 03-02-2015, 08:30 PM
cstone94's Avatar
Perfect!! You're the man!
Old 03-04-2015, 07:38 AM
cstone94's Avatar
Well, the master cylinder didn't help.... gonna try a slave cylinder.
Old 06-22-2015, 09:22 PM
cstone94's Avatar
Okay, so I've still been battling with this on and off. Some days the clutch will work fine, some it's kinda iffy, and some days not at all. Like today for instance... Drove around town all day, went to work, got ready to leave work, no clutch. Wouldn't go in any gear with the car on. Started the car in 1st and it pulled itself forward and started just enough to rev match and get it home. Clutch in at 60 and still in 5th gear = no RPM changes at all. Time for a whole new clutch assembly?
Old 06-23-2015, 06:18 AM
cstone94's Avatar
http://www.ebay.com/itm/XTD-STAGE-3-CLUTCH-KIT-94-01-ACURA-INTEGRA-B18-RS-LS-GSR-GS-R-TYPE-R-/191596470197?hash=item2c9c0a1fb5&vxp=mtr
Anyone had any luck with these?? If they aren't bad I'll get one, otherwise I'll go with an Exedy.
Old 06-23-2015, 07:46 AM
cstone94's Avatar
Okay another quick update! So like I said last night clutch was no good all the way home from work. Get in it this morning and still nothing. Pull it in the garage, check fluid, its fine, the slave cylinder is rusty looking, looks like a bit of brake fluid is making its way around the fitting... Paint is missing from the slave so I go in and pump the pedal for about 30 seconds, fire it up, and it acts perfectly normal... This is the 3rd slave cylinder... Or maybe the fitting is bad and leaking?
Old 06-26-2015, 01:25 PM
cstone94's Avatar
Anybody? Acted fine since last post until today.
Old 06-26-2015, 01:34 PM
JulIop209's Avatar
Liquidgsr
03-31-2007 12:14 PM
RDAYA0
12-14-2006 05:31 PM
Ri5e
10
09-22-2004 05:36 AM
SloCivicHMM
05-12-2003 01:57 PM
vteg
08-01-2002 03:10 PM
Quick Reply: 92 Hatch Clutch Problems
