95 honda civic 1.6L crank but no start
I've done my distributor,timing,spark plugs,fuel lines filter and pump,new battery,compression test I'm at loss what am I missing? Please help?
Re: 95 honda civic 1.6L crank but no start
Turn key from off to ON(II) and then listen for whether the fuel pump runs (buzzing noise below rear seats) for 2 seconds and then turns off. Also watch whether the CEL turns on and off after 2 seconds.
Is spark bright white at all 4 plugs?
How do you know?
And yes spark plugs all tested spark
and timing is on
I've done timing before its backfiring so.it shouldn't backfire if it was the timing And yes all 4 sparks bright white and no cel codes
Yes the buzzing sound when you turn the key over once before you try and crank it it was making the buzzing sound and I checked my fuel injectors and its getting fuel. Is there anyway that if fuel is in the oil that could make it not start?
Have you actually checked the mechanical timing?
FYI, this statement of Ron's is a subtle warning that he is near walking away from your issue:So here is a word to the wise:
Failure to follow his directions precisely and/or report back in detail what you did to follow his directions will prevent you from receiving his expert advise and you will likely be stuck on your own to get this dialed in and working properly. Quite often the secret is in the details so omitting them makes life impossible for all involved.
I'll now return you to the very prolific RonJ as he is being extra patient with you and running you through the proper diagnostic procedures. If you follow his advise concisely and report back in detail how you followed his exact steps, you will have a running car shortly or know specifically what is wrong and needs repair.
Best of luck.
MintyCivic
03-06-2016 03:52 PM
infinkc
02-21-2013 01:32 PM
Speardog
07-24-2010 08:20 PM
