Clutch replacement DIY
Hey,
I searched and I couldn't find a write up on how to replace a clutch. I need to replace the clutch on a d16y8. I have a new clutch but I don't really know transmission stuff. How hard is it to replace a clutch? There has to be a diy posted around here, I just can't find it. Let me know.
Thanks
Thanks
Ek Forever y0!
Re: Clutch replacement DIY (okdc2)
» Search Results
Your search for clutch DIY returned 16 results.
DIY act clutch install
https://honda-tech.com/zerothread?id=923640
DIY clutch install
https://honda-tech.com/zerothread?id=380884
Tranny removal
https://honda-tech.com/zerothread?id=811691
Tranny inspection if you like
https://honda-tech.com/zerothread?id=644885
Bitch pin removal if you have problems
https://honda-tech.com/zerothread?id=470849
Changing tranny fluid
https://honda-tech.com/zerothread?id=851521
Input shaft bearing replacement (I recommend replacing IPS bearing and throught bearing when doing a clutch replacement.)
https://honda-tech.com/zerothread?id=596873
DIY clutch install
Tranny removal
I just got mine put back together it's not hard just a lot of work.
you WILL need....
a torq wrench (I had 2 a 20-150ft/lb and a 5-80ft/lb)
a ball joint popper... (Jc Whitney PN# ZX812149N)
http://<br /> <a href="http://www.jc...9190</a><br />
The hayes service manual (for torq specs)
and a pickel fork (for getting the cv joints out of the trans.)
1-2 cans of break cleaner
Jack
Jack stands (large ones if you got um')
Full set of metric whrenches and sockets.
and a lot of patients.
not a diy but a ton of pics of my install...
http://<br /> <a href="http://usm.fa...094</a> <br />
you WILL need....
Jack
Re: Clutch replacement DIY (ek forever guy)
yea my first one. took me a while but I learned tons!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Congrats on the clutch job btw if that was your first time. </TD></TR></TABLE>
xunkn0vvnx
03-30-2005 07:52 AM
