starting problem...
starting problem...
Whenever I go to start my car, nothing happens. The engine won't turn. The starter was replaced about 3 months ago and I even hit on that to see if that was the problem but no luck. Anybody have any suggestions to get the thing started?
Ek Forever y0!
Re: (hon da top)
Engine wont turn eh?
Try your battery, check your plugs/wires
make sure your dizzy is okay and hasn't been flipped around or anything.
I'm betting on the battery though.
I also had problems with the fuel system earlier in the week... i think. The car was trying to start but wouldn't. So i replaced the coil... that wasn't it. So when i would try to start it if i gave it a little gas it would start. And now it won't do anything.
Ek Forever y0!
Re: (hon da top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">Don't think its the battery, the stereo, lights, everything will turn on but the engine won't turn. </TD></TR></TABLE>
That doesnt mean jack, you're battery may not have enough amperage to turn the crank. Turning the crank requires much more powertha your radio and lights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">I also had problems with the fuel system earlier in the week... i think. The car was trying to start but wouldn't. So i replaced the coil... that wasn't it. So when i would try to start it if i gave it a little gas it would start. And now it won't do anything.</TD></TR></TABLE>
Giving a fuel injected car gas to get it to start won't do anything.
Lemme get this straight, you replaced the coil in the alternator for a fuel problem?
Have you taken it to autozone to get your starter and battery tested?
Have you checked for spark? Is your fuel pump priming?
Well I didn't know it was a fuel problem at first, so i replaced the coil. Should I try to jumpstart the car? The fuel pump is priming...
im having the same exact problems..i wrapped a wire around the little clip plug on the starter...then tapped it to the positive post on the battery and the car will crank...if i try with the ignition it just sits there..idk wtf is goin on
Ek Forever y0!
Re: (blackKready)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">you need a starter dude , starter solenoid is done , happens alot.</TD></TR></TABLE>
How are you so positive over the internet? It could be the solenoid or 60 other things.
IMO I would rule out the solenoid on a new starter.
Ek Forever y0!
Re: (hon da top)
I've told you everything I can think of. I'm spent bro.
https://honda-tech.com/zerosearch
» Search Results
Your search for wont start returned 324 results.
» Search Results
Your search for starting problem returned 108 results.
» Search Results
Your search for civic start returned 190 results.
» Search Results
Your search for start returned 265 results.
There, 887 threads for you to browse.
If you can't find it there I'll jump off a cliff.
» Search Results
» Search Results
» Search Results
» Search Results
