Crx Resistor box into a 97 ex honda civic turboed
I must be typing in the wrong keyword for the search to come up so my question is . I know the wires i bhave to splice are the yellow where on the drivers side underneath the hood to the top right. Now which ones have to be connect to which. I have a resistor box out of a SI crx it has 5 wires.
Ek Forever y0!
Re: Crx Resistor box into a 97 ex honda civic turboed (Frost7177)
why are you putting an obd0 anything into an obd2 car.
Please tell me english wasn't your first language. Because I have no Idea what you're try to say.
Maybe it's just my dumbass to proper english translator that's messing up.
Re: Crx Resistor box into a 97 ex honda civic turboed (ek forever guy)
Ive been reading the posts since im upgraded my injectors for the stock honda injectors to Mitsu eclipse GSX 450 injectors. They either put a prelude resistor box in or a Crx Si one in. Does anyone know which wires the resisitor box matchs up to. To slpice into the yellow wires on the engine harness on the drivers side? My car is obd1 now becuase of the chipped ecu.
You should have 5 wires total on the resistor box. Four of them should be one color, like black and the 5th wire should be a different color. I think red. On your injector harness, cut the yellow/black wires(4 of them) and connect them together to the one wire on the resistor box that is red. Then, the 4 wires that you have coming off the resistor box, connect them to the other side of the 4 wires you cut off that go to the injector plugs. If you want pictures, search on here for RESISTOR BOX.
Re: Crx Resistor box into a 97 ex honda civic turboed (ek99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 »</TD></TR><TR><TD CLASS="quote">You should have 5 wires total on the resistor box. Four of them should be one color, like black and the 5th wire should be a different color. I think red. On your injector harness, cut the yellow/black wires(4 of them) and connect them together to the one wire on the resistor box that is red. Then, the 4 wires that you have coming off the resistor box, connect them to the other side of the 4 wires you cut off that go to the injector plugs. If you want pictures, search on here for RESISTOR BOX.</TD></TR></TABLE>
I understand what you are saying and it helps alot, but I have one question. Do the 4 wires that are coming out of the resistor box have to be wired in any particular order to the injectors?
BoostBoi
11-13-2004 11:50 PM
