oil in the dizzy?
oil in the dizzy?
ok i have been having a frustrating hesitation issue above 4k today i took the time to seafoam, new fuel filter, oil change and a msd cap and rotor (i also have a msd igniton w/blaster ss coil) and i changed the igniter when i took the igniter out there was oil in the dizzy with some on the old igniter. i wiped it clean put the new igniter in and test drove the car. problem solved it ran perfect. now io go out two hours later and the problem is back not nearly as bad as before but back. i'm thinking its because of the oil i found in the dizzy but where is it coming from? how do i fix it?
Re: oil in the dizzy? (messeduprex)
Maybe a leak ? oil comingin from the engine ....
its motor oil right ?
i would say a leak ... take the dizzy out completely and check it out ...
good luck
good luck
Re: oil in the dizzy? (HCJDM1)
yeah it looks like motor oil and i don't understand how it could get in. i have a small hole for the wires of the scsi hook up but there was to much to just get in thta way
Budget Racer
29
03-29-2008 12:05 PM
