Pulled plugs, Gangsta lean!
So i pulled my plugs, and they are white! Pretty much lean. They have never been lean, after 10k miles. Ive had plugs last 40k with no sight of whiteness.
I have replaced my fuel pump, filter, fuel pump filter. And my fuel pressure is
35psi with vac line connected, and 45 wiht it not connected.
Im using a 1995 talon ESI fuel pump, however the fuel pressure numbers are within spec, so why for the lean mixture?
Re: Pulled plugs, Gangsta lean! (YoungKadafi)
reading plug is only accurate when u run the car full throttle every time, coz when u are on freeway with light throttle, the ecu take out fuel to save gas, u will see 15-16 afr during that.
Location: chillin in that city called queen creek, but homes the atl
Re: Pulled plugs, Gangsta lean! (spoon_ek9)
and stock fuel pressure is 35 dam its been so long since i've been stock
you have a wideband o2 sensor? Take it out on the freeway and check it. You can always up for fuel pressure if the regulator is adjustable or go get a nice street tune to ensure you're around stoich.
NO fuel pressure... car was running then lost all pressure, Aeromotive, dual walbro, stainless lines
HickamHatch
09-24-2008 02:01 PM
