94 honda civic ex won't start
I've got gas and spark.
I've got 12v at the injectors
where is the ECU?
what else. Benn running fine the last year and just decided not to start for wife. Which is not good
where is the ECU?
Unceasing Measure
Re: 94 honda civic ex won't start (speedswing)
How do you know you have spark? What color is it? If it's not blue, your coil is probably on its way out. Are you sure your timing belt didn't snap?
Does your interior lights come on...hear any click coming from your starter? Any kind of noise come on when you try to start???
Engine cranks and cranks
I pulled the dist cap and got the crap shocked out of me on the rotor button when my wife was cranking it.
However, I pulled a plug and did not see any spark
I did smell gas on the plug.
I'm confused
I'm confused
pull your oil cap and have someone crank it and look through the valvecover to see if the camshaft is turning, if not = broken timing belt.
Ek Forever y0!
Re: (Hondacivic90ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondacivic90ed »</TD></TR><TR><TD CLASS="quote">pull your oil cap and have someone crank it and look through the valvecover to see if the camshaft is turning, if not = broken timing belt.</TD></TR></TABLE>
Or he could take the timing belt cover off.
Ek Forever y0!
Re: (speedswing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedswing »</TD></TR><TR><TD CLASS="quote">The valves are moving. I assume the timing belt is ok? I hope so probable less than 5k on the new belt.</TD></TR></TABLE>
Then your belt should be fine.
Re: (ek forever guy)
do these engines have a problem with the distributor?
I took the cap off to make sure the rotor button was spinning and it was.
any other ides?
any other ides?
Ek Forever y0!
Re: (speedswing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerosearch
» Search Results
Your search for wont start returned 324 results.
» Search Results
Your search for starting problem returned 108 results.
» Search Results
Your search for civic start returned 190 results.
» Search Results
Your search for start returned 265 results.
There, 887 threads for you to browse.
If you can't find it there I'll jump off a cliff.
» Search Results
» Search Results
» Search Results
» Search Results
I don't have a book. any place on the net where I can see a pic of where my main relays and such are?
I should be able to check it if I know where it is.
I replaced ing mod and rotor button and cap then I had spark.
however, it turned over a good 30 sec before it caught and started.
I guess it's ok.
at least it's running
I guess it's ok.
ya you're right taking off the timing belt cover is way easier then spinning the oil cap off and taking a look.
Mr learns alot
02-28-2014 08:11 PM
JDM-sol 89
02-14-2012 01:50 PM
