d16y8 1996 honda civic ex 4dr
Hey all,
First post
My car . 344.000k and just replace all three drive belt. (a/c ,p/s,alt,) 3 new goodyear gator belts. change oil castrol 5w30 3.3L in....24 hours later bad noise coming out from engine bay... i thing it's the P/S pump , also think it the a/c tensioner bearing.... maybe i place the belts to tight on all three. causing the bottom cam bearing to go....help me to try to fix this...
i am not looking to replace the engine ...
First post
Re: d16y8 1996 honda civic ex 4dr (BADHDRIVER)
With the car running, put your ear to a LONG ratchet extension or screwdriver and touch it to each of the aforementioned parts.
See where the noise is coming from.
Re: d16y8 1996 honda civic ex 4dr (t0p_sh0tta)
try that with my mechanic stethoscope and noise is mostly coming from tensioner...and p/s pump ...
the thing is the noise is very bad ..
sound close to a medium cat growling with metal banging...engine idle
but rev it to 3000 rpm no more banging...
i now that i am almost answering my own question but i am just trying to make sure that i don't get a plowing piston in my face going to work or make it worst...
help pls...
Modified by BADHDRIVER at 8:00 PM 4/1/2007
Modified by BADHDRIVER at 8:38 PM 4/1/2007
help pls...
Change the idler pulley and see if the noise stops.
BTW, a piston won't hit you in the face. Usually, if it's not a knocking noise, it's not fatal.
i found the problem it was the a/c idler bearing.
So i replace the bearing for $10.00 re-re the bearing from my steel pully...
So guys thank you very much again and hope to you anytime when you need help..
freshgear
02-26-2020 12:20 PM
you2envious
06-21-2002 04:00 PM
