acura integra gsr shiftlinkage not fit on a 94 eg hatch with a gsr
the stock gsr integra shiftlinkage came with my swap
seems to bolt and slide on trans right and bolt to the body but it hits the body about a foot away from the trans.
i cant even move the shifter
Re: acura integra gsr shiftlinkage not fit on a 94 eg hatch with a gsr (94eg5squadMD)
it will fit. cause i am using it.u are swapping a b series into eg,right?and remove the shifter first,and the shiftlinkage will bolt on. or maybe the shiftlinkage is bent?
you have no idea what came with the swap
you know what was supposed to come with the swap.
from what you're describing are you saying the ends of the linkage don't reach? or the shaft of it is hitting the body and it does reach?
sounds like it was either bent, or you have i upside down.
Re: (instrument)
i will have pictures today. the shift linkage isnt bent. and it hits the body where the heat shield for the exahust was. its about 2 ft away from the trans on the body?
Cool Cool Island Breezes. BOY-EE
Re: (94eg5squadMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg5squadMD »</TD></TR><TR><TD CLASS="quote">i will have pictures today. the shift linkage isnt bent. and it hits the body where the heat shield for the exahust was. its about 2 ft away from the trans on the body?
It's on backwards probably
it is the linkage is twisted un bolt the likage from the tranny and just under then bolt back on. Also it cant be backwards unless twisted is what you are talking about. All Bseries shift linkage will fit all beseries in any eg,dc,da,ek,and ej. Good luck
Re: acura integra gsr shiftlinkage not fit on a 94 eg hatch with a gsr (Mostecstreethb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mostecstreethb »</TD></TR><TR><TD CLASS="quote"> it is the linkage is twisted un bolt the likage from the tranny and just under then bolt back on. Also it cant be backwards unless twisted is what you are talking about. All Bseries shift linkage will fit all beseries in any eg,dc,da,ek,and ej. Good luck</TD></TR></TABLE>
The del sol VTEC linkage is longer.
del sol vtec linkage should not be in this equation.
check if you have one part of the linkage on backwards. then compare the your d-series linkage to your gsr linkage see if they are different.
SLVR08
01-28-2011 06:09 AM
92civichatch1
03-08-2006 08:54 AM
mrtrex
11-27-2005 03:36 PM
