Starter Problem just exchanged nothing!!! D16Z6
After normal driving yesterday I turn off my car to get some food...Come back outside and get ready to go . I try to crank no noise from the starter nothing... So i didnt wanna pop my hood in front of the hang out so i just tell friends to push start it and boom good to go... I drive off to a autozone to pop my hood and check if maybe ground wire fell or something. Ground wire is on good again i turned it off tried again nothing. Today I banged on the starter to see if it was going bad ...Nothing again..So i had a spare starter tried it out in auto parts test came out good switched starters now im back to where i was at yesterday nothing... I checked the ground on the starter its nice and tight both terminals on battery nice and tight...Battery is fully charged. The car will only start if i Push start it ...Check the 7.5 Starter Signal came out good anything else i need to check???
can you elaborate on what you are saying? The battery to starter wire is connected and is making contact (found out the hard way) so what else can I look at???
Re: (92EG8)
Well if you have a good ground the main 12 v power and the starter signal all there when you turn the key. the only thing left is a bad starter or you are missing one of the first 3 items.
well i took a voltometer to the starter and has positive 13+ power going to the starter as well as good ground . I just changed the starter to eliminate the starter being the problem what else can i look into the 7.5 Fuse was just replaced
Ehh ill look for this signal wire... So far i see the big *** wire from the battery to the startert which is checked and nicely put on... then thats all the wire i see attached where is the signal wire?
i dont even hear a click coming from the starter only working on push start it has to be something with connections or w.e cuz i changed the starter to a new one same problem... what grounds do i need to check?
ok got some new info i jumped the starter signal and the start cranked...so from here and on what can i do to diagnose and find the solution to my problem?
