b16 swap shift linkang???
first i had an LS and recently put in a b16 ... now i have a gsr tranny with gsr shift linkage.. everything was bolted down tightly... now both motor gave me this problem: it tends to lossen up and my shift **** is all over the place.. i have to look for my gears and its sittin on my exausht pipe... anyhelp????
Re: b16 swap shift linkang??? (SumOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote">first i had an LS and recently put in a b16 ... now i have a gsr tranny with gsr shift linkage.. everything was bolted down tightly... now both motor gave me this problem: it tends to lossen up and my shift **** is all over the place.. i have to look for my gears and its sittin on my exausht pipe... anyhelp????</TD></TR></TABLE>
it wasn't torqued down during the install. just get under the car and torque it down.
Re: b16 swap shift linkang??? (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 »</TD></TR><TR><TD CLASS="quote">You are terrible at explaining your problem. What do you mean, 'look for my gears' ? Your shifter has play? </TD></TR></TABLE>
actually it's his explanation is pretty simple. he's looking for his gears, meaning just that. never had gear trouble before huh?
Re: b16 swap shift linkang??? (philosofy1)
thank u phil... but i have to look for the gears cuz its so damn loose..and its sittin on the exhust piping.. eddie ill be in town tonight.. see u later
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote"> eddie ill be in town tonight.. see u later</TD></TR></TABLE>
there are only 2 bolts to be tightened up.crawl under the car and u will see them.and also FYI. LS and GSR shiftlinkages are the same
or there is another situation that happened to me once,exactly the same problem that u encounter now....u got the seal boot installed upside down.what i mean seal boot is number 11 in the pic shown below or u are missing number 8 in the pic shown below
Re: b16 swap shift linkang??? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">there are only 2 bolts to be tightened up.crawl under the car and u will see them.and also FYI. LS and GSR shiftlinkages are the same
this is not his case.
#11 was upside, you wouldn't be able to put the shifter in, and even if you can, it would be clear as day that it's wrong.
and part #8, yeah, if that was missing it would be nearly impossible to drive your car. i had this break one time so i should know.
i had the same issue
just go under the car and start wiggling parts of your linkage around, there should be NOTHING that "wiggles"
i fixed mine with a series of well placed washers.
Re: (instrument)
Did you use a "Bitch Pin" I know people say you can shove a bolt in there and it will feel tight but it will never be as good as a bitch pin. Make sure all your bolts are tightened, Maybe your bolts that hold the linkage to the body fell out, there two 12mm bolts. Goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
#11 was upside, you wouldn't be able to put the shifter in, and even if you can, it would be clear as day that it's wrong.</TD></TR></TABLE>
hi dude.this happened to me once thats why i understand his situation.the shifter would be sit on the exhaust pipe.it was number 11 installed upside down.and u can still put everything back on tight
hi dude.this happened to me once thats why i understand his situation.the shifter would be sit on the exhaust pipe.it was number 11 installed upside down.and u can still put everything back on tight</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">solved the problem yet ?</TD></TR></TABLE>
looks like the people who did the swap shoved a del sol linkage in there. along with the rubber boot a plastic ring is shot. the bushing for the stabilizer bar is what really broke and was making the shifter sit on the exhaust.
i am currently in the process of reparing.
well like phil said the guy who did my swap put in a short shift linkage.. and its not in dead center of the hole of the body and my rubber boot was gone.. phil put in a new one and tighen down the bolts and wala!! but im still pist at the fact that i have a short shift linkage and i get alot of hot air in my car...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SumOne »</TD></TR><TR><TD CLASS="quote">well like phil said the guy who did my swap put in a short shift linkage.. and its not in dead center of the hole of the body and my rubber boot was gone.. phil put in a new one and tighen down the bolts and wala!! but im still pist at the fact that i have a short shift linkage and i get alot of hot air in my car... </TD></TR></TABLE>
hey, i left a message, hit me for the part #'s!
i got the bracket for the AC now i just need the compressor and bolts to put it on oh yeah and the pully i need to find FAWK!
HELLAnorcal
11-28-2006 06:15 PM
j_wod2000
07-27-2005 07:10 PM
