ready to boost??
ready to boost??
have a 99 si with 142k on it
but rebuilt the engin in 05 with about 7k on it
rebuild parts:
r&r motor and deck block
3 angle valve jobs,new guid,new valve steam seals
oem water pump, oem oil pump, oem motor mount
forged h beam eagle rods
forged pistons 10 to 1
street/stripe clutch kit 6 puck
new head gasket, intake manifold, valve cover gasket
hondata gasket and motor mount inserts
act streetlite flywheel
greddy timing belt b16
aebs head studs b16
nuform block guard and motor mount inserts
bottom end assembly with new bearings,main and rod bearung, polished crank shaft, resurface
i use this car as a daily driver and wonderin if this would be a good ideato boost?, i pretty much just want a fun reliable car that can put out about 200-250 whp!
rebuild parts:
aebs head studs b16
Re: ready to boost?? (duckmajor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duckmajor »</TD></TR><TR><TD CLASS="quote">
i use this car as a daily driver and wonderin if this would be a good ideato boost?, i pretty much just want a fun reliable car that can put out about 200-250 whp!</TD></TR></TABLE>
As long as you've done your research, install everything properly, and dont beat the living **** out of your car, you can expect to have it last you a great deal of time, close to that of if it were stil N/A.
Keyword here; Do your homework, do your research, ask ppl who do run boost.
because Knowing is half the battle..
* "G I jooeeee" *
* "G I jooeeee" *
Re: ready to boost?? (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
* "G I jooeeee" *</TD></TR></TABLE>
