crooked engine, tranny mount?
alright , i have a 92 4 door lx, and i did a auto to manual conversion on this car..
now before i got this car i helped my friend put an engine in it, and it was sitting crooked..
do i need a special mount from the transmission to the body so the engine sits striaght??? i heard of these mounts hasport has to offer. but is that neccessairy and am i missing something.
Guest
Posts: n/a
what i did when i did a auto to manual swap i went to the junk yard and cut the manual tranny mount out of the car and then drilled the spot welds out and put the motor in and tacked it place and then welded it all up and its good to go or you can by the mount from hasport
Re: (isaacson06)
You need to get the manual trans mounts for your civic just goo to the junk yard and remove them. I believe you need to replace the front bracket, Rear T- Bracket, And the top mount bracket. Somebody correct me if I am wrong.
Re: crooked engine, tranny mount? (blackfoot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackfoot »</TD></TR><TR><TD CLASS="quote">alright , i have a 92 4 door lx, and i did a auto to manual conversion on this car..
do i need a special mount from the transmission to the body so the engine sits striaght??? i heard of these mounts hasport has to offer. but is that neccessairy and am i missing something. </TD></TR></TABLE>
yeah it's all nice eveyone saying to just get the manual bracket and reweld it onto your car, but hasport, innovative, and jdmshit all carry the auto conversion mount. it's a plug n play affair and is 10x easier than cutting, lining, welding a new bracket.
hasport sells the mount for auto to manual conversion. If you dont want to do that you can drill out the mount (not sure about wording) that is attached to the car re-weld it so that 5 speed mount fits perfect. I did this to my car about a year ago. I did a quick search and found a write up on the whole thing.
redsikiller
22
05-15-2006 01:46 PM
getnasty
11-17-2005 12:56 PM
Si Integra
03-09-2005 12:38 PM
