power window slowing down when going up
I have a 93 civic coupe.... an when ever i go to put up da passenger window is goes up fine until it reaches half way there. The driver side sames to workin just fine it's the passenger that won't work properly.... n'e idea what the problem is?
Modified by Casp3r88 at 10:48 AM 8/25/2007
Re: power window slowing down when going up (Casp3r88)
It might have follen off its guide. Happend to me a while back. You can take the door panel off and see. You'll definately see your problem is when you do this.
Re: power window slowing down when going up (h2392si)
the run channels on my civic went bad and got those replaced by the dealer, and its umteen times faster now
could also be the motor going. i have a similar problem with my 94 civic. i've found that if you do one window at time with all powered things off (i.e. radio, lights, wipers) they work a little faster
acuracer
12-16-2001 12:45 PM
