Need help with my EK9 CTR cluster...
So I got an EK9 CTR cluster to go in my 2000 Si. On the back of the Si cluster there is a green recepticle for the green harness clip off the Si wiring harness. But on the back of the CTR cluster there is no green recepticle, only a brown one. This brown one is shaped slightly different than the green one, so the Si wiring won't fit into it.
How'd you guys get around this? Is the green wiring necessary to be plugged in (what does it run)? Or did you dremel or otherwise manipulate the brown recepticle to receive the green harness?
Si cluster is on top, CTR is on the bottom.
Re: (JDM4LIF3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM4LIF3 »</TD></TR><TR><TD CLASS="quote">dont worry about it that green plug is for your seat belt light. just leave it off it will be ok.</TD></TR></TABLE>
Thanks for replying, bud Not sure if that's it though, I just hooked up the cluster and the seatbelt light works fine (light on when belt is un-plugged, shuts off when belt is plugged).
In front of the brown recepticle on the CTR cluster is the light for "ABS" which, of course, the 2000 Si didn't come with.
In front of the green recepticle on the Si cluster is the light for the Cruise Control, which they must not have had on the CTR 'cause I don't see that light on the CTR cluster.
So if someone can corroborate that on here, that the green one on the Si is for cruise control and the brown one on the CTR is for ABS, then I'll be stoked that I figured it out
Re: (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC »</TD></TR><TR><TD CLASS="quote">Thanks guys, should be good to go
that looks sick!
that looks sick!
Re: (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC »</TD></TR><TR><TD CLASS="quote">So if someone can corroborate that on here, that the green one on the Si is for cruise control and the orange one on the CTR is for ABS, then I'll be stoked that I figured it out </TD></TR></TABLE>
This is correct
This is correct
zseeanz
10-19-2004 07:53 PM
