94 ex coupe into 94 cx hatch
Old 08-23-2007, 11:22 AM
velocit's Avatar
Default 94 ex coupe into 94 cx hatch
will the rear trailing arms with disc brakes from a 94 civic coupe fit a 94 cx hatchback with drums and if so any modifications needed ??? also the doors the ex are all power ,will i be able to swap the doors too?
Old 08-23-2007, 11:23 AM
95ProjectEJ1's Avatar
Default Re: 94 ex coupe into 94 cx hatch (velocit)
Does the coupe have ABS? Im assuming its an EX with the rear disc option? I dont remember if the rear disc only came as an option itself or with the ABS
Old 08-23-2007, 11:33 AM
velocit's Avatar
Default Re: 94 ex coupe into 94 cx hatch (95ProjectEJ1)
yes it does have ABS
Old 08-23-2007, 11:35 AM
Someone please chime in and educate me on this, but I believe I heard that if you are doing a rear brake swap and your car is Non-ABS, that the disc assembly must be Non-ABS as well.
Like I said, someone please chime in and correct this if it is indeed not true.
Old 08-23-2007, 11:42 AM
velocit's Avatar
really, so is it possible?
Old 08-23-2007, 11:44 AM
It you said that the coupe was non-abs I would have said that it would be a direct change over, but since its ABS to Non-ABS im a little hesitant to give a definite "yes its possible"
Old 08-23-2007, 11:48 AM
velocit's Avatar
well thanks for the info , what do u think about the door issue ?
Old 08-23-2007, 11:49 AM
The EX doors will swap over, but you will need the floor harness as well. Try and search the FAQ, I believe there may be a write up on how-to.
EDIT: Found it ---&gt; <FONT COLOR="red">https://honda-tech.com/zerothread?id=1065575</FONT>
Old 08-23-2007, 11:56 AM
B18bEG6ick's Avatar
here you go for the write up on the doors.
http://repo.jackmoves.com/v/erik/albun31/albun42
if you don't want the doors send it to me. haha. as for the brakes i'm not too sure about the abs part, but i know that the front brakes on the 94-95 has a bigger rotors.
velocit's Avatar
thanks!!!!!!!
Old 08-23-2007, 11:57 AM
velocit's Avatar
Default Re: 94 ex coupe into 94 cx hatch (B18bEG6ick)
thanks for that info
Old 08-23-2007, 12:06 PM
B18bEG6ick's Avatar
i think you can change it over. just don't use the abs stuff and the sensors.
Old 08-23-2007, 12:16 PM
velocit's Avatar
thanks !!!!!
Old 08-23-2007, 12:21 PM
t0p_sh0tta's Avatar
It doesn't matter that the rear brakes are ABS compatible. Everything will function properly.
Old 08-23-2007, 12:28 PM
velocit's Avatar
Default Re: 94 ex coupe into 94 cx hatch (t0p_sh0tta)
do you know of any write ups on the topic or any other info ?
Old 08-23-2007, 12:30 PM
t0p_sh0tta's Avatar
Not off the top of my head, but there should be one in the FAQ at the top of the page. It's relatively straigtht forward.
redlinexd
11-30-2008 05:00 AM
ej6joe
27
02-17-2008 05:10 PM
supdawg2
08-26-2004 08:45 PM
SpoonFedHatch
12-10-2003 09:48 AM
DavidTurbo
03-24-2003 06:14 AM
Quick Reply: 94 ex coupe into 94 cx hatch
