High idle and speedometer going crazy
Hi guys i have a 97 civic hatch auto with a y7 engine.
This morning i started my car spedo was acting like a tachometer and idle was really high (id guess around 1800 i dont have a tach). I cleaned aicv, cleaned the grounds , and changed vss. Another weird thing was that i used my blinker and the d4 icon on dash started blinking and trans is having problems shifting like it searches through gears . I hot a big pot hole the night before could it all be related ?
Could it be a short ?
Re: High idle and speedometer going crazy
Check the cluster ground which is behind the cluster. Also inspect the wires on the back of the engine, where they go through the intake manifold bracket and over to the alternator and speed sensor, etc. This is easiest from underneath the car.
I pulled 8 codes including the p1298 code which is eld from what I have read do you guys think it could be the root of all the other codes? I will check the bundle behind the intake mani
The other codes p0108 map high voltage
P0113 a it high input
P0501 vehicle speed sensors
Po135 and p0141 o2 sensor 1 and 2 malfunction
P0700 trans control malfunction
P0720 output speed sensor circuit malfunction
RiTtEk401
10
10-01-2011 02:23 PM
mrehagencivic
04-20-2005 02:12 PM
DannyITR
07-21-2004 05:10 PM
Integra_Boi
09-17-2002 11:55 AM
