Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
Old 09-02-2016, 11:25 AM
Type 56's Avatar
Default Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
My engine start up is experiencing rough idle @ 2500 rpm. The check engine light is on and the code reads P0122, which is a Throttle Position Sensor/Switch A Circuit Low Input. So i'm pretty sure that my TPS is causing the rough idling. I've thought about the calibrating the throttle body, but considering how old the motor is and the shape of the TPS it is in, i figured i should try to at least replace it to make sure that i'm working with a brand new unmolested TPS and not a POS. But before i ordered myself a new one, i just wanted ask, is all 92-00 Honda TPS the same? I mean, like, are they interchangeable?
Old 09-03-2016, 08:16 AM
Former User's Avatar
Default re: Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
Honda-Tech - Announcements in Forum : Honda Civic / Del Sol (1992 - 2000)
Old 11-03-2022, 08:56 AM
Jtjimenez's Avatar
Default Re: Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the sa
How's the timing? Are you able to drive it or does it stall once you start it? Any check engine lights?
410ruga
03-25-2014 12:07 AM
got00rice
12-30-2009 12:16 PM
92ehatch
11-13-2006 02:33 PM
ludacole
08-13-2005 11:59 PM
mafay2
07-04-2005 06:35 PM
Quick Reply: Rough Idle @ 2500 rpm and CEL code P0122 - Are all 92-00 Civic TPS sensors the same?
