B16a3 Vacuum line help
Old 10-27-2016, 07:52 AM
Juarez97's Avatar
Default B16a3 Vacuum line help
Alright so i have 94 del sol vtec with a b16a3
ive been having issues with my RPMs fluctuating, there was hoses that were just clossed off and other parts that didnt even have hoses, i seem to have gotten everything back in place and if i close off the nipple in the middle of the intake mannifold with my thumb, the rpms stop fluctuating. That was one of the parts that didnt have a hose, also ive looked at other intakes and behind the engine towrds the bottom center there is a hole where a pcv valve goes in? As you can see my car doesnt have anything and there is one last hose that is closed off that comes from the bottom. Id like to know exactly what parts are these, their functions and if they belong together. Thank you very much, i think these last things will solve the problems im having.
Old 10-27-2016, 08:19 AM
talks to himself
CX-Adam's Avatar
Default re: B16a3 Vacuum line help
If everything is stock, you can go on Hondahookup's website and download the Service Manual. It'll have detailed diagrams of all the hose connections. RonJ has also been known to post the figures here.
Old 10-27-2016, 08:26 AM
Juarez97's Avatar
Thanks ill check that out right away!
Old 10-27-2016, 09:02 AM
Premium Member
94 Civic Si's Avatar
Looks like not much in the del Sol section :-(
Del Sol - Downloads - Hondahookup.com
Old 10-27-2016, 09:22 AM
talks to himself
CX-Adam's Avatar
Yeah, the Del Sol info is sparse. Fortunately the B-Series engine is used in several platforms. Just look up information for a OBDI b-series from the Civic and Integra manuals.
Old 10-27-2016, 11:43 AM
mk378's Avatar
Honda Automotive Parts
The hose you have in your hand in the first picture is #5. Your car is missing the valve itself (7), and the lower hose (4) which fits into the hole in the intake casting between cylinders 3 and 4, and possibly other parts of the system that is attached to the back of the engine below the manifold.
The hose in the second picture does not look stock.
Old 10-27-2016, 01:05 PM
Juarez97's Avatar
Thats what i figured, my friend was telling me that the pcv valve just goes there with no tube in the bottom which confused me like crazy, on picture three, its not very clear but where my fingers are, there is a nipple which i guess has a hose connected to the pcv valve, which then has a hose connected to the intake manifold. Right now i have the pcv valve open with no hose on the bottom, i used a tee to connect all three.
Old 10-27-2016, 02:25 PM
Former User's Avatar
Default Re: Vacuum line help
Does this help?
If you follow the hose in the second pic, does it run to the breather box? edit: mk found a better illustration.
Old 10-27-2016, 06:26 PM
Juarez97's Avatar
Default Re: B16a3 Vacuum line help
Ok so the nipple on the middle of the manifold intake has a hose that leads to a pcv valve. That pcv valve leads to a grommet, which goes on the empty hole between the intake manifold and the engine block. That grommet is actually a hose also, honda made them as one piece. Then that leads to another nipple, which is on the chamber breather, and boom! Problem solved. Thank you all for your help that was a fast fix!
Old 10-28-2016, 09:01 AM
Premium Member
That is awesome - Congratulations!
chazla86
11-03-2013 06:57 PM
angrysmileyface
11-08-2012 10:06 AM
Anonymous User
05-04-2011 03:16 PM
ch00dlz
01-23-2006 05:16 AM
EGSR-T
09-10-2005 01:58 PM
Quick Reply: B16a3 Vacuum line help
