99 EM1 - No check engine light
Aloha everyone. So my 99 em1 suddenly popped up with a "no check engine light" on the cluster. Bulb seems good and even when I try other good working bulbs, nothing happens, all of the other warning lights work,etc but yes, wen I turn the key on, theirs nothing their,failed at the emmisions place in az,that's how I found out. I tried googling it but people jus had bad bulbs and jus want to know where to look, I know some Honda Ek goddesses can help a Braddah out ;-)
re: 99 EM1 - No check engine light
If you bought the car used and it has never worked for you, someone may have cut the wire at the ECU end. That little trick can be easier than taking the cluster out to remove the bulb.
Please contribute to this forum by updating your past threads below. Members get frustrated when they search for answers only to find threads where no solution is posted.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-civic-si-speedo-crazy-3261607/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/99-em1-obd1-alternator-question-3286890/
Re: 99 EM1 - No check engine light
Sorry been busy, I had a extra cluster I jus swapped in and works fine now, ya my old si cluster was working fine cel wise but magically stopped working. Really weird. Thanks and mahalos everyone ;+)
636lover
17
02-22-2020 06:37 AM
Nathan_volcom
06-10-2012 09:34 AM
