my car is tilted to my driver side.
I have my stock suspension on at the moment and its tilting to the my driverside..
i had my k sports in there before and it did the same thing. what do you guys think is wrong? doesnt look like there is frame damage
same thing happened when i used my aftermarket suspension and they were same height
here are some pictures of it
this is very common. it ususally happens after tightening the lca bolts with the car off the ground and the suspension hanging. the suspension bolts must be tightened with full weight of the car on them.
Re: my car is tilted to my driver side. (bottle-fed-bitch)
Definetly looks like your rear LCA is binding. loosen the bolts at the frame and hub with the car on the ground then retighten
Location: everything for everyone, and nothing for ourselves
Re: my car is tilted to my driver side. (alphalanos)
what did u break fatty?
seriously, i've heard about the whole lca bushings binding. causes premature wear.
Re: (turboteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg90 »</TD></TR><TR><TD CLASS="quote">where your exaust pipe,i dont see it,it should be huge if your runnin turbo</TD></TR></TABLE>
no...a good kit will tuck it in nicely.
even with 3 inch dp a good kit downpipe will not be seen.
Re: (lollypopking)
wow... rice.
its called having a profesinal installing/ welding it in... gosh go getta fart pipe.
but yeah i had this same problem istalled new stuts and springs flatend it rite out :>
wow... rice.
Re: (luvmihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmihatch »</TD></TR><TR><TD CLASS="quote">
wow... rice.
but yeah i had this same problem istalled new stuts and springs flatend it rite out :></TD></TR></TABLE>
Jesus, everything is rice now...
wow... rice.
Re: (hgem1si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hgem1si »</TD></TR><TR><TD CLASS="quote">
Jesus, everything is rice now... </TD></TR></TABLE>
it's true things that wernet ricey before have fallen into the rice catergory
Re: (v!taminb16)
i have the same problem on my EK too.
my car tilted on the driver side when it was still on stock suspension and now that is on a full coilovers is still tilted on the driver side.
B serious
01-07-2016 02:00 PM
PiXeL
03-23-2006 10:11 AM
