Water pump help!
Old 03-21-2008, 07:19 PM
magicmyst98's Avatar
Default Water pump help!
i went searching the forums and couldn't figure it out...
Just installed a new timing belt and water pump on my d16z6. Nothing special to it but when the car's idling I can hear this rubbing noise and the timing belt seems to be flapping somewhat on the waterpump side. The belt is tightened down right. Is it possible to have a brand new water pump with a bad bearing? Or did I over tighten my timing belt? I'm completely lost...help!
Old 03-22-2008, 06:26 AM
Default Re: Water pump help! (magicmyst98)
just took a video of my engine...
http://www.youtube.com/watch?v=nqv5bwXs9mA
and yes i know my valves are ticking. was gonna regap them when this sound stumped me.
Old 03-22-2008, 07:04 AM
Luserkid's Avatar
Sounds like your timing belt might be a little to tight. Try redoing the tenstion on it again. Also what cam gear is that? Is it set to 0?
Old 03-22-2008, 07:07 AM
Default Re: Water pump help! (Luserkid)
its an str cam gear. its on 0. i do have a stage 2 camshaft in it but i never had an issue with the sound before.
Old 03-22-2008, 09:00 AM
bump
Old 03-22-2008, 12:02 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like your timing belt might be a little to tight. Try redoing the tenstion on it again. </TD></TR></TABLE>
Old 03-22-2008, 01:29 PM
old man neri's Avatar
It was hard to tell from the video but it sort of looked like your alternator belt was rubbing against your timing belt cover. Is it? The sound it is making sounds like something is rubbing, are there any marks on any of your belts?
Old 03-22-2008, 02:53 PM
Blzdeep's Avatar
Default Re: (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">It was hard to tell from the video but it sort of looked like your alternator belt was rubbing against your timing belt cover. Is it? The sound it is making sounds like something is rubbing, are there any marks on any of your belts?</TD></TR></TABLE>
Old 03-22-2008, 04:41 PM
hey thanks guys. checked everything over and over. verdict was i overtightened the timing belt. its running nice and smooth now
06-17-2009 05:19 PM
globy123
08-08-2008 08:38 AM
B18C1NMotion
11-20-2007 11:27 AM
civic_tuned
23
07-26-2005 08:42 AM
0 0 0
05-31-2003 05:28 AM
Quick Reply: Water pump help!
