Rear brake piston problems.... Help!
So I have rear disks on my EG, and i'm trying to swap out my pads but the [freak]ing rear piston barely budges.
I'm able to barely turn it, but I can't get it to go in much further. I even have that little cube thing but it barely fits in the caliper.
My question is, is there anything I can do to make this thing go in more? Its pretty much seizing. Is it possible to just put on the front pad, and drive it to a brake shop and get them to do it? This **** is driving me nuts.
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">a prybar that has a flat tip...thats wut everyone at my work uses</TD></TR></TABLE>
how would you use a prybar to compress a piston?
i use a C clamp
that way if it is anti lock i can twist the piston as i compress it
i use a C clamp
Re: (95jeremie)
That the same problem that i was having with my 93 civic Si . i got tired of it so i went to go buy some new calipers at advanced auto and it worked fine , give or take like 4 to 5 month later i tried to replace the pads . and the some ****, the pistons would not move still trying to figure out what is the problem. if not i iam just going to go get some new ones at Honda ..... GOOD LUCK MAN
Re: Rear brake piston problems.... Help! (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie »</TD></TR><TR><TD CLASS="quote">anti lock brakes?
remove the cap to your master cylinder to help relieve pressure?
No ABS.
Tried that, didnt make it any easier...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMILYHIGHTUNED »</TD></TR><TR><TD CLASS="quote">That the same problem that i was having with my 93 civic Si . i got tired of it so i went to go buy some new calipers at advanced auto and it worked fine , give or take like 4 to 5 month later i tried to replace the pads . and the some ****, the pistons would not move still trying to figure out what is the problem. if not i iam just going to go get some new ones at Honda ..... GOOD LUCK MAN</TD></TR></TABLE>
Yeah its a real pain in the ***...
I just threw the shitty pads back on, the brake isnt even working, but I drove it around to see how it drove, seems fine. Tomorrow i'm going to drive it to a shop and have them do it...
No ABS.
The rear caliper puck must be turned and pressed in at the same time. Failure to do so will damage the ebrake mech inside the rear caliper. If you are unable to turn and press the caliper puck back in then you will need to replace the caliper assy. The reman runs around $75 after the return of the core.
BB4lude
02-11-2008 01:47 PM
wickedxbo1
12-30-2001 07:51 PM
