Brakelines....
Brakelines....
does anyone know if 94-01 acura integra brake lines will fit into a 92 civic with the factory mounted prop valve with no modification? thanks
Re: Brakelines.... (crazyguy)
so the lines that go to the proportioning valve are exactly the same and the integra prop valve is in the same location as the EG's?
Re: Brakelines.... (Ep1dem1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ep1dem1c »</TD></TR><TR><TD CLASS="quote">so the lines that go to the proportioning valve are exactly the same and the integra prop valve is in the same location as the EG's?</TD></TR></TABLE>
the lines go to prop valve? brake lines are from fenders to calipers/drums only, front brake lines are about 1.5 feet and rear brake lines are about half feet.. if u want to add a integra 40/40 proportional valve to eg chassis. u will need to modify the line at the engine bay.
so the lines that go to the prop valve arent brake lines? lol what are they then?
i want to know if can hook the brakelines from an integra to an EG the lines inside the engine bay....
i want to know if can hook the brakelines from an integra to an EG the lines inside the engine bay....</TD></TR></TABLE>
yesh they will. but u will have to bend them to fit.
hefftone79
07-05-2009 04:19 PM
SpoonSportsJunkie
06-06-2007 01:45 PM
