check engine light!!! o2 sensor? codes?
i just changes heads on my z1 block to a z6. check engine light comes on. i think its due to the o2 sensor. being that i changed heads do i need to change the o2 sensor as well? and how do i check for what code it might be? thanks if u can help
Re: check engine light!!! o2 sensor? codes? (vxtirent08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxtirent08 »</TD></TR><TR><TD CLASS="quote">i did what the thread said and the check engine light never blinked. so what does that meen?</TD></TR></TABLE>
your probably doing it wrong ?
this is pretty much how you find stuff out with using a comp tool, mabie something is really messed up with ur ecu...
Modified by id3379 at 11:03 PM 3/22/2008
